rounded bolt removal
Old Feb 1, 2009 | 03:43 PM
R5COS's Avatar
R5COS
Default rounded bolt removal
im sure some of you would of came across a rounded bolt head at some stage, question is how do you get it off, weld a nut to the bolt head, try and hammer a smaller socket onto it ?? im open to ideas, 2 of my 4 front anti roll bar bolts are rounded off
Old Feb 1, 2009 | 03:48 PM
lawnsy's Avatar
lawnsy
you can buy bolt extractors that just twist on anti clock wise and they grip and remove the bolt or nut.... iv'e got a set of snap-on ones but machine mart sell them to and are just as good......they work every time too... ill try and find a pic
Old Feb 1, 2009 | 03:51 PM
lawnsy's Avatar
lawnsy
http://www.machinemart.co.uk/shop/pr...grip-set/path/
nilrem's Avatar
nilrem
STOP!... Carry on
that or a good grip on a pair of molegrips!
Old Feb 1, 2009 | 03:52 PM
lawnsy's Avatar
lawnsy
And the expantion pack.......
http://www.machinemart.co.uk/shop/pr...-bolt-grip-set
Old Feb 1, 2009 | 03:54 PM
R5COS's Avatar
R5COS
thank you that man
Old Feb 1, 2009 | 05:38 PM
cabriolet's Avatar
cabriolet
get in plumbing box stillsons best tool for job never been known to fail as long as u can get them on the nut and turn them made for gripping round tube always works for me
Old Feb 8, 2009 | 06:58 PM
gtit's Avatar
gtit
they irwins r good, sounds the same as the boys snapon gear
Old Feb 8, 2009 | 07:36 PM
I personally would HEAT these by welding a bar/nut whatever on, this has the added effect of helping to loosen anyway.
Using no heat means more likelyhood of the bolt snapping, they chassis cut open inside car to fix etc, whereas a bit of heat, even better from a torch will be much much better to start with.
Old Feb 18, 2009 | 02:18 PM
leveup's Avatar
leveup
is really useful for me
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
BRAM
Sep 8, 2015 07:11 AM
hopper350
Sep 4, 2015 12:53 AM
