Help with Clifford Concept 50
Old Feb 1, 2009 | 09:42 AM
Project_XR2i_Trackcar's Avatar
Default Help with Clifford Concept 50
I have a Clifford Concept 50 fitted to my Mk6 RS2000 and to be honest, its being a right PITA.
At the moment the car wont start unless its on jump leads. Without jump leads, all that is working is the alarm itself and the central locking.
Without the jump leads the dash lights are illuminated still but do not dim when attempting to start (indicating a flat battery), the electric windows wont open either. IIRC it wont turn over, the key just turns with nothing.
Now i'm hoping that simply a new battery is needed. It seems wierd that it will start with jump leads but not at all without. I'm assuming the imobiliser isnt causing it as surely it woulnt start with the jump leads on.
Confused
Any Clifford veterans out there care to help?
Old Feb 1, 2009 | 09:43 AM
Nowt to do with the alarm, is purely not enough juice.
Old Feb 1, 2009 | 09:46 AM
Thanks for the reply, i really do hope it is that simple.
Old Feb 1, 2009 | 11:36 AM
sailorbob's Avatar
sailorbob
The Concept 50 doesn't like low battery voltage, even when there seemed to be a reasonable voltage my old one used to activate the immobiliser. A healthy battery and alternator will keep it happy
Old Feb 1, 2009 | 03:53 PM
philip_d's Avatar
philip_d
Nope, battery is fine! almost new and fully charged! done a drop test on the battery aswell, and hold charge fine. Its somethink to do with the alarm, now can't even start with a jump start??
I'm chris's brother by the way.
Old Feb 1, 2009 | 03:59 PM
sailorbob's Avatar
sailorbob
I'd check the supplies and earths to the Clifford system next then.
Old Feb 1, 2009 | 05:50 PM
cabriolet's Avatar
cabriolet
resistance test battery leads had this on agolf earth seemed ok until it burned half the loom earths out i only had it in to investigate poor charging when i tested it the earth resistance was horrendous took the plastic off the wire was black and powdery bastard fried the coil as well
original
Apr 28, 2026 05:20 PM
Steve Escos
Alloy wheels and ICE for sale
14
May 8, 2019 02:45 PM
S2martin
Oct 21, 2004 06:41 PM
Kevin B
Jul 7, 2004 07:43 AM
zvhturbo
13
Jun 15, 2004 02:44 PM
