frst starter/flywheel?
Old Jan 31, 2009 | 03:27 PM
fiestaturbo1984's Avatar
fiestaturbo1984
Default frst starter/flywheel?
hey guys,having probs with my frst. when i brought it was told it needed a starter, so got a 2nd hand one.when i started the car the started stayed engaged and made a horrible grinding noise. i thought starter could be naff, so got one from a breaker, same thing happened. ive just brought a brand new bosch unit so i can safely take it out of the equation as being a problem and the same thing happened again.
does anybody have any idea why this could be happening?
Old Jan 31, 2009 | 03:31 PM
B16CVH's Avatar
B16CVH
Sounds like the power which kicks the starter into action when you turn the key forward is not cutting out as you turn the key back??
Old Jan 31, 2009 | 03:32 PM
fiestaturbo1984
how could i check this? any idea on which wires to check?
Old Feb 1, 2009 | 05:03 PM
fiestaturbo1984
ok im pissed off now.took the starter out, left it wired in and earthed it. got my mate to turn the key for a second and let it return.the starter did as it should, tried again and again and everytime i did, the same thing happened.
i now have no idea wha else to check other than takin the box off and looking at the flywheel but it looks ok when looking through where the starter bolts on.. heres a pic...
Old Feb 1, 2009 | 05:33 PM
cabriolet's Avatar
cabriolet
ok geezer here we go the engine only normally stops in two places u need to look through the hole and turn the engine if its there u will find itmeasure the distance between two dentils [ie across one tooth] should b approximately 10mm if it is ring gear is right
Billy_RS
16
Oct 11, 2025 09:41 PM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
bigryrs
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
