Which head
Old Jan 25, 2009 | 10:04 PM
darrenr1969's Avatar
darrenr1969
Default Which head
I currently have a standard 88 mk2 xr2 and am about to start and modify it..
Iam going down the old fashioned route of ,head,cam,twin 40,s etc..
Its just a weekend blaster so lairy cam,head is what iam after.it wont have to sit in traffic every day.
Now onto my main question can a rs turbo cam/head or a xr3i xr2i cam/head be used on my carbed cvh as these are more readily available,or can i only use a xr2;xr3 one...thanks in advance...
Old Jan 26, 2009 | 07:13 PM
B16CVH's Avatar
B16CVH
Your head will be the lean-burn type so you cannot use a 3i/RS head unless you change the pistons for Hemis
Old Jan 26, 2009 | 08:01 PM
darrenr1969
so its a leanburn type only then..it would be wouldn,t it
Old Jan 26, 2009 | 08:43 PM
B16CVH's Avatar
B16CVH
Always the way, you can get good resuts from a tuned lean-burn head, i did one for a friend of mine a few years back and it was a flyer. I would go down the bike carb route as opposed to the 40s, they are way more reliable and cheaper to buy.
Old Jan 26, 2009 | 08:54 PM
darrenr1969
Do you have any advice on what bike carbs to use and also inlet manifold ,linkages,and jetting etc....
Old Jan 27, 2009 | 06:40 AM
Tb's are the way to go, but depends on budget, but a lot use tb's from bikes, any carb/s is a backward step, but what some want.
Old Jan 27, 2009 | 06:47 AM
Garage19's Avatar
Garage19
Tabetha, you haven't factored in cost. I could do a bike carb conversion on a cvh for about £30. To use bike tbs and an ecu would cost me £400 min. That's a big difference.
Old Jan 27, 2009 | 08:18 PM
darrenr1969
also, are bike carbs capable of producing as much power as 40,s on a cvh...
Old Jan 27, 2009 | 08:21 PM
B16CVH's Avatar
B16CVH
I would say they are capable of more power to be honest, they seem to have the edge over 40s, 40s now are getting old wheras bike carbs from a modern motorbike have moved on and more advanced. Its not very often you see a motorbike lacking power!
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
