Overboosting @ 14PSI ????
Old Oct 10, 2003 | 09:31 AM
TurboBlower's Avatar
TurboBlower
Default Overboosting @ 14PSI ????
My S1 overboosts as soon as i hit 14PSI of boost and even my local rollers cant understand it ???
I used to be able to run upto 21PSI (Not Advisable) on my Standard Turbo before any probs...
Now Ive fitted a Chargecooler and Brand New Stage 3 T3 running on incar adjustable boost, i cant boost above 14PSI
Ive contacted the Turbo Supplier who were very helpful and say that overboosting has nothing to do with the actual Turbo and from what i can see all my pipes are ok.
I took it to the local rollers to get set up with the boost peaking @ 17psi dropping to 15psi but he couldnt get it do this boost because of the overboosting and he couldnt understand why ???? any ideas peeps????
All Suggestions Appreciated PeePs Im lost with this One?????
CheeRS Adi
Old Oct 10, 2003 | 11:30 AM
Stu @ M Developments's Avatar
PassionFords Creator
What are "you" calling overboosting mate?
Old Oct 10, 2003 | 11:46 AM
TurboBlower
Popping and Banging as soon as it hits 14psi. on the incar adjuster i can turn the boost to 13psi and its fine as soon as i turn it a little bit more it does the above.
help
Old Oct 10, 2003 | 04:03 PM
Does the rev counter turn off at the same time?
Old Oct 11, 2003 | 06:04 PM
Chances are its not hitting the overboost protection built in to the managment, prob summat else, an ign problem...
Old Oct 14, 2003 | 02:29 PM
TurboBlower
Sorted this one boys...
I was running Bosch Super 4's for plugs with a snd plug gap.
Spoke to M.A.D. told me my overboost limit on my chip was 1.5 bar and asked what plugs i was using?? told him the above and he laughed.. told me to bang some NGK's in with a gap of.28mm and bobs your uncle and susans your auntie away we go with 17psi of boost and as smooth as you like through the power now
whaaaaaaayyyyy.
CheeRS for the replys lads.....
Adi..
Old Oct 15, 2003 | 10:49 AM
Forgot all about this post!
Didnt think it sounded like overboost
jonny gav
Ford Focus RS
Jun 8, 2005 11:27 AM
SteveW
Ford Escort RS Cosworth
Feb 28, 2005 11:03 PM
Dave Henshall
Dec 20, 2004 07:39 AM
007
Nov 14, 2004 05:15 PM
TurboBlower
Oct 14, 2003 02:50 PM
