Escos P8 Phase 0 chip
Old Dec 2, 2004 | 06:14 PM
Dave Henshall's Avatar
Dave Henshall
Default Escos P8 Phase 0 chip
does the std P8 ecu in bigturbo escos cars not need a board like the std 4x4 L8 saphs ?
i know the std escos progrm allows overboost upto around 14psi for about 5 seconds and then drops back to around 10 psi, what would a "phase 0" chip do, would it be more of a drivability chip than a nomal "stage 1" chip which allows around 1 bar(15psi) of boost normally?
im just interested as there is a Well Lane Phase 0 chip sitting with my std blue injecotrs that i removed to fit the pectel board, chip and greens.
the car ran like a bag'O'wank before this but this was down to the wiring which has since been resolved fully and the new stg 3 setup installed.
so, what difference (if any) over std would there be with a Phase 0 chip ?
Old Dec 3, 2004 | 02:41 PM
markk's Avatar
markk
no board required on p8 !
Old Dec 20, 2004 | 04:16 AM
Billabong's Avatar
Billabong
Escort RS Cosworth Phase 0 = +40 bhp (Phase 0 is Superchips terminology), reprogrammed chip & boost increase - makes the car considerably less laggy/more lively.
Phase one is similar but usually with de-cat exhaust & air filter & more boost (& possibly light green injectors?)
Phase two is the 'usual' greens/3 bar setup.
Old Dec 20, 2004 | 07:39 AM
Dave Henshall
that would explain why when i spoke to someone else about it - they said, they thought well lane used superchips - (obviously with their own sticker on instead).
tankybaby66
Feb 6, 2016 02:24 PM
gcfcos
59
Oct 6, 2015 05:04 PM
A.t.p
Sep 29, 2015 05:04 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
