pats wiring problems on an RS2000 engine
Old Jan 5, 2009 | 07:55 PM
van man stu's Avatar
van man stu
stu
Default pats wiring problems on an RS2000 engine
hi got problems trying to get my 1995 RS2000 engine to run
ive recently put the lump into a mk 6 escort van. But only had an engine loom when got the engine (last minute decision) now i have an engine in, it turns over theres spark but the pats unit seems to be cutting off the power to the injectors the wiring seems to have been altered at some point the key readers there and wired up but in all the black wires to the pat unit some seem to be cut HELP!! i need a new loom i think
Old Jan 5, 2009 | 09:49 PM
derekd's Avatar
derekd
have you got a non pats ecu there?? should work on a non pats ecu mate without changing the loom?
Old Jan 6, 2009 | 07:56 AM
Is it cutting just the live feed to the injectors as this can just be tied in with igntion somewhere esle, I doubt if it's cutting all 4 earths to them.
Old Jan 6, 2009 | 06:24 PM
van man stu
stu
Default pats problems
witch mk was the non pats ecu thanks
Old Jan 6, 2009 | 06:38 PM
van man stu
stu
it is cutting all the live feeds but been trying to get a wiring diagram to aid in rewiring but i was not having much luck with that either thats why i thought the new loom would be easyier
Old Jan 6, 2009 | 06:58 PM
derekd's Avatar
derekd
pop on rs2000-16v.co.uk mate you will get all the info u need and a ecu if you need one
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
muz
Aug 16, 2015 12:57 PM
gingerturbo
Aug 11, 2015 09:44 PM
