Car not re-starting when hot, why???????
Old Jan 5, 2009 | 10:30 AM
sparkydale's Avatar
sparkydale
Default Car not re-starting when hot, why???????
was wondering if there is anyone who can shine a bit of light on my problem i seem to be having. i have never been into modifying cars, and to be honest, i dont know anythig about cars, however, i have recently acquired my little baby, a 2 litre mark 6 escort RS 2000, now, when its hot, like if i have been driving it for a while, when i turn the engine off, to say, put petrol in etc, when i go to restart it it doesnt start. like the other evening i was sitting in traffic and it was getting hot, and the fan was working its nuts off to cool it down, then i stopped to get petrol and it wouldnt start, a mere 50 minutes later it decided to start with a bit of a pop from the exhaust. does anyone have any idea. please help.
Old Jan 5, 2009 | 11:17 AM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
I'd be looking at starter motor first mate...
The pop from exhaust was probably just unburnt fuel from all the turning over.
Old Jan 5, 2009 | 12:02 PM
smudge_lad's Avatar
smudge_lad
does it turn over when you try to start it?
I had the same problem with mine a wee while ago (1.6 CVH EFi Turbo), turned out to be the power cable to the starter motor was too close to the block and the plastic casing had melted away, so the bare wire was shorting-out so the starter wouldnt even turn over.
If I left it for while it would start no probs, or if I got a jump start.
If it turns over, then I'd imagine the starter is maybe not the problem? Always something to check though
Old Jan 5, 2009 | 12:18 PM
rog's Avatar
rog
I don't see it being any of the above TBH, more like a temperature sensor or plug gap being wrong.
Old Jan 5, 2009 | 12:36 PM
pani_k's Avatar
pani_k
PassionFORD Member
If it does it randomly and when cold too I would've said starter motor but if it only does it when hot then it would suggest a problem related to temperature so something it obviously doesn't like when warm.
Old Jan 5, 2009 | 01:11 PM
If it's turning over all right, then I wouldlook at anything that upsets the mixture, even a air leak, split hose etc can do it, they run very lean mixes these days, so worth a free check first.
Old Jan 5, 2009 | 01:23 PM
martysmartie's Avatar
martysmartie
Sounds as thought Fuel may also be related I.E fuel vapor lock.
kosienutter
31
Aug 22, 2015 09:55 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
dojj
Aug 12, 2015 08:52 PM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
