Focus pulling to the right
Old Jan 3, 2009 | 08:26 PM
Allyc85's Avatar
Allyc85
Default Focus pulling to the right
My Focus seems to have a strange problem in that after going around left handers il return the steering to the middle and itl pull to the right. when out for a spirited drive shall we say its been a bit dodgy a couple times as ive gone for a right hander and cut the corner alot with very little steering imput . Its done this for a while now and I was hoping that the new suspension kit and drop links i had put on would fix this but its still there.
Ive had 4 wheel alignment done, checked the tightness of the bolts on the suspension and found that theres no free play anywhere. So I was hoping that someone else has had a similar experience so I can finally get this sorted.
The car is a V reg, 1.8 Focus Hatch
Cheers.
Old Jan 3, 2009 | 09:08 PM
Alvyn's Avatar
Alvyn
wish bones worn????????
Old Jan 4, 2009 | 03:48 PM
Allyc85's Avatar
Allyc85
Its possible but they look ok i.e. the bushes havnt pulled out and they arnt cracked. Will have another look though.
Should also mention that the car accelerates and brakes totally straight, its just after left handers lol.
Old Jan 4, 2009 | 05:08 PM
Check for sticky calipers, then check the wheelbase is equal either side of the car, between the front and rear wheel.
Old Jan 4, 2009 | 08:37 PM
Allyc85's Avatar
Allyc85
Will do, got disc and pads all round to do anyway so will take a good look at the calipers.
TPM961
Jan 15, 2018 10:50 AM
37
Sep 17, 2015 05:05 PM
Fudgey
Sep 17, 2015 01:06 PM
The Enigma
Sep 12, 2015 10:12 PM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
