escort rear wheel bearings
Old Jan 1, 2009 | 11:44 AM
cabriolet's Avatar
cabriolet
Unhappy escort rear wheel bearings
cant get more than 12 months out of a pattern rear wheel bearing anyone else have the same problem and anyone found a solution
Old Jan 1, 2009 | 11:45 AM
kellyalfie's Avatar
kellyalfie
all bearing are skf even fords
Old Jan 1, 2009 | 11:47 AM
RichieST's Avatar
RichieST
what wheels do you have? If they are the wrong offset they will knacker wheel bearings in no time.
Old Jan 1, 2009 | 11:58 AM
cabriolet's Avatar
cabriolet
have 2 mk6 escorts one on escort ghia rims one on mondeo 6spokes both suffer the same problems
Old Jan 1, 2009 | 05:58 PM
cossie604's Avatar
cossie604
Check the condition of your stub axles and also the hub wear your bearings press into.....although as you say you have two cars with the same problem I'd be looking at maybe the workmanship ie is something not being done correctly as apposed to wear else where causing premature wear (lol that sounds odd).
Old Feb 10, 2010 | 11:04 PM
nigel.b's Avatar
nigel.b
I had the same problem with my nearside wheel bearing, turned out it was the hub, am having same problem now with the offside but can't get a wheelhub anywhere, they are like rocking horse xxxx!
Old Feb 11, 2010 | 09:32 AM
As said worth checking the hubs, not a ford but my old w reg metro used to spin the bearings in the hub, every year new bearings and hubs/discs/pads for mot without fail!!
Vincereese
Jun 1, 2023 09:14 AM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
malkiemac3579
Jul 14, 2017 12:10 PM
Vincereese
Aug 18, 2015 03:57 PM
muz
Aug 1, 2015 06:48 AM
