Temprature Problem
Old Dec 30, 2008 | 08:30 PM
Darren1593's Avatar
Darren1593
Zetec-S
Default Temprature Problem
just went to the chinese for some thing to eat and was out for a matter of 10 minutes, the heaters were on full blast aswell
wen back into the car after getting my food and noticed the temp gauge was right up.
is this a thermostat fault ??
it is an 02 plate fiesta zetec-s if this helps.
CheeRS Darren
Old Dec 30, 2008 | 09:15 PM
Phil2002's Avatar
Phil2002
if your heaters were blowing hot then i doubt its the thermostate because if the stat was stuck shut not allowing the water to get through then the heater matrix will not be getting any hot water and therefore would blow cold air. it may be as simple as the temp sender is fucked or the wire from the sender has shorted to earth. if the wire has shorted to earth the temp gauge will go straight to the red with just the ignition on and the engine not running.
but on the bad side it could be head gasket!!!
hope this helps,
cheers,
Phil
Old Dec 30, 2008 | 09:27 PM
Darren1593's Avatar
Darren1593
Zetec-S
the heaters were just blowing cold air thats why i thought thermostat
Old Dec 30, 2008 | 10:47 PM
Darren1593's Avatar
Darren1593
Zetec-S
its ok Pavl has helped me out on this one
hopefully hes right
Old Dec 31, 2008 | 07:23 AM
LHD220Turbo's Avatar
LHD220Turbo
if the heaters were blowing cold; and the car overheated you might have cooked it
it could be the stat as said above; get a sniff test done on the headgasket; kets hope you havent cooked it
Old Dec 31, 2008 | 01:29 PM
Darren1593's Avatar
Darren1593
Zetec-S
pavl said it happened to his fiesta aswell and said it could just be the heater control valve.
Old Dec 31, 2008 | 01:38 PM
Phil2002's Avatar
Phil2002
just take the stat out and see if it still over heats the heater will blow cold with no stat. if it over heats with the stat out then theres a problem else where. a sniff test is a good suggestion if the stat turns out to be ok.
you can check the stat by putting it in a kettle to see if it opens when the water boils.
cheers,
Phil
Old Jan 1, 2009 | 06:11 PM
Darren1593's Avatar
Darren1593
Zetec-S
cheers guys will take the stat out and see if it opens, when i get time though.
Old Jan 10, 2009 | 10:41 AM
Darren1593's Avatar
Darren1593
Zetec-S
i have now got hot air coming out of me heaters and the temp gauge has not rised since i changed the part this morning so if it goes up again i will need to ask u guys for more help
CheeRS for yuor help guys
and Pavl_RS for your help
Old Jan 10, 2009 | 11:11 AM
Just rev the engnie and keep an eye on the temp gauge and see if the fan cuts in.
Old Jan 10, 2009 | 03:48 PM
Darren1593's Avatar
Darren1593
Zetec-S
have been out since half one and the car temp gauge never went above half way, but i will just keep my eye on things for now
CheeRS guys
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
