coked head
Old Dec 30, 2008 | 08:23 PM
Phil2002's Avatar
Phil2002
Default coked head
Can some one please tell me the best way to remove all the carbon off my zetec head and valves its quite bad.
can i use caustic soda???
cheers,
Phil
Old Dec 31, 2008 | 07:13 PM
Phil2002's Avatar
Phil2002
bump..................anyone
Old Jan 1, 2009 | 08:25 AM
The valves I just use a bench grinder with a wire wheel, works perfect.
For the head I use a attachment in a drill, gently though.
Old Jan 1, 2009 | 12:34 PM
cabriolet's Avatar
cabriolet
a pillar drill also works well on valves agree with tabetha on the head his warning really is important very easy to damage the head
Old Jan 1, 2009 | 12:49 PM
Phil2002's Avatar
Phil2002
thanks for the advice. i'll be having the head skimmed after in what way can i damage the head??
cheers,
Phil
Old Jan 1, 2009 | 12:50 PM
Phil2002's Avatar
Phil2002
also if i get a wire wheel for my dremel is it ok to use this on the exhaust ports to clean off the carbon????
thanks for the replys,
Phil
Old Jan 1, 2009 | 01:01 PM
cabriolet's Avatar
cabriolet
deep scratches gouges would upset airflow on a ported head could ruin all the good work if u had had it done also remember the metal is not very thick doubt if a wire brush for a dremel will be man enough a electric drill and a cheap decoke set would be better
Old Jan 1, 2009 | 01:20 PM
I use a rotary pointed wire brush attachment in the drill, just don't go gouging metal away.
Old Jan 1, 2009 | 01:31 PM
Phil2002's Avatar
Phil2002
i won't thanks for the advise!!
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
