Xr2 Cvh Cams
Old Dec 29, 2008 | 05:26 PM
jhot80's Avatar
jhot80
Default Xr2 Cvh Cams
Hi there,
I trying to figure what cams and wether the get a modified head from burton or somewhere when i rebuild the cvh in my xr2. to the point what is the highest lift cam you can use in a standard cvh head?
cheers james
Old Dec 29, 2008 | 06:13 PM
mechanic28's Avatar
mechanic28
think its just a fast road one u can use with standard lifters etc!cvh22 i think??
i got a stage 2 head from burtons for my mk2 xr2 around 6 years ago!i was not impressed!was told that it had the modified stem seals so did not bother too check,fitted head and it smoked like a bitch!only to find it had the old style stem seals !and the valves were not lapped in!
Old Dec 29, 2008 | 10:46 PM
mk2rstaff's Avatar
mk2rstaff
just keep your eyes peeled on flea bay or here should pick up a decent modded head somewhere mate
Old Dec 31, 2008 | 02:21 PM
legend289's Avatar
legend289
The valve seats were probably cut on a Serdi machine or similar where you shouldn`t lap the valves. Lapping them destroys the seat, they work beautifully if cut correctly and vacuum tested afterwards.
Old Dec 31, 2008 | 09:20 PM
mechanic28's Avatar
mechanic28
my head was aweful when i took it off and done a leak check on the valves with liquid within hour nearly all the liquid had seeped past the valves
Old Dec 31, 2008 | 09:24 PM
kellyalfie's Avatar
kellyalfie
try ht racing at brands hatch mate they are very good ive had work done by them 100% worth the wait in my book
mondeomark
Sep 28, 2015 06:28 AM
