**** ICE PROBLEM****
Old Nov 20, 2004 | 04:36 PM
stusfesta's Avatar
stusfesta
Default **** ICE PROBLEM****
hi ive just put my amps in my new car and im getting interference from the engine and just a humming when the engines off. All the wires where in the car already, i spoke to the bloke who had the car and he had no probs. i think its something to do with the earths as it really rumbles when i muck about with them. any ideas? appreciate any help thanks
stu
Old Nov 20, 2004 | 05:12 PM
RS220Turbo's Avatar
RS220Turbo
all u need is a good earth mate. and check to see if the speaker wires aint touching.
Old Nov 20, 2004 | 05:56 PM
stusfesta's Avatar
stusfesta
it does it with the amp for the speakers and the amp for the sub though? even if i turn the sub off at the headunit and then turn the volume up the sud still lets out the odd rumble. grrrrr
Old Nov 20, 2004 | 07:31 PM
steviep's Avatar
steviep
Had this problem in one of my old cars.
It turned out to be the power lead running too close to the alternater, re-routed it and interference stopped, job done.
Old Nov 21, 2004 | 12:35 AM
stusfesta's Avatar
stusfesta
hmm dont think its that on mine as my battery is rite at the back, cheers anyway mate
Old Nov 21, 2004 | 01:56 PM
luke89's Avatar
luke89
Team HOTHOT!
just a shot in the dark could it be any think to do with the remote wire ?? check all the conections to the amp check the wires on the sub and maby try moving the earth or taking it off and making shore theres nothing stoping it from tuching bear metal . check the wires on the back of the head unit as well . if it still does it i dont no
Old Nov 21, 2004 | 09:04 PM
sm's Avatar
sm
what are the amps mounted on ie back of a sub/ or on the back of the back seat? mine was mounted on the back of the back seat, metal to metal and had interferance, now mounted on the back of my subs and it stopped
Old Nov 22, 2004 | 01:13 PM
davidnormanuk's Avatar
davidnormanuk
You can get an adaptor that plugs into your amp leads from your head unit that cuts down the interference. Had this problem on a mondeo.
Worth a try as it was only around Ł6 from unicar in leeds.
Dave
Old Nov 22, 2004 | 05:04 PM
stusfesta's Avatar
stusfesta
hi, my amps are sitting on carpet, it interferes even when i switch the lights on, i recon its a bad earth somewhere, maybe from the alternator? ive put a new remote wire in aswell
cheers guys
Old Dec 8, 2004 | 04:07 AM
escort1989uk's Avatar
escort1989uk
noise compressor needed about 6 quid from any audio supplier
Old Dec 15, 2004 | 12:43 AM
turboboi's Avatar
turboboi
noise supressors are pointless tehy just aid the problem not fix it...it could be that youre RCAs are run too close to power/earth wires...the alternator creates an AC voltage that is rectified to 12V DC this AC voltage can 'jump' across to speaker/rcas if run too closely
more than likely its a bad earth tho remove all of them and clean em up properly
it wont be the remote tahts impossible as long as you have 12V going down it there is no problem because it puts no audio signal in so it couldnt possible create noise
Old Dec 16, 2004 | 06:13 PM
stusfesta's Avatar
stusfesta
well its definatly the rca's as ive been to an audio specialist, we tried new rca's run over the top of the seats,everything. the bloke recons its the headunit as we put a different unit in and it works fine. I only bought my headunit couple of months back! damn Bass Junkies!
K3V HA
Ford Escort RS Cosworth
39
Mar 18, 2005 08:11 PM
CabrioTurbo
Dec 16, 2004 05:30 PM
Stavros
Oct 8, 2004 07:37 AM
cossied
Aug 5, 2004 07:19 PM
13
Apr 5, 2004 10:32 PM
