Strange starting problems
Old Dec 22, 2008 | 03:14 PM
mcallister-smith's Avatar
mcallister-smith
Default Strange starting problems
Bassically my xr3i (mfi) can start fine no probs atall then some times it can start then cut out and i have to keep switching the ignition on an off untill i here a buzzing sound from the engine bay then it fires, anyone heard of this problem and advice me on what to do to solve it, i personally think its todo with fuel pump?
Old Dec 22, 2008 | 04:31 PM
I would agree it does sound like the fuel pump, is stopping, some just wire it so it is on permanently, as it regulates the pressure anyway, have done this a few times on 2.8i capris.
Old Dec 22, 2008 | 08:07 PM
mcallister-smith
Doesnt cut out when driving tho? just after ive switched it off then start it again, say 15mins later
Old Dec 23, 2008 | 01:22 AM
It sounds just like a dicky relay, I think on these there is a relay on the n/s inner wing for the pump control, but not familiar with these at all.
It is most likely the vibration of driving keeping the relay working or the pressure is rising falling if duff and just not bad enough yet to notice the lowering fuel pressure.
It will cause absolutely no harm running constantly like a efi version, as it is regulated anyway.
You could try a new pump relay if you want.
Old Aug 26, 2009 | 02:35 PM
Aaronk8749's Avatar
Aaronk8749
no fuel pump relay is a pink one under the dash at drivers side just sorta hangs there lol
check your fuse box for i think a 15 or 20 amp fuse maybe not totally damaged but usually crack
don't know why but its printed on fuse box lid as electric heated seats but the fuse box lid is totally wrong, its the main fuel system fuse, i changed mine couple of days ago
Old Aug 28, 2009 | 06:52 PM
craig66's Avatar
craig66
if i was you id change the fuel relay as they are common for being fault like that if you listen to the relay it should click when the pump is priming then when it wont prime it wont click which isnt making a connection if you take the top of the rely of and use u instulated screwdriver and push the two metal parts together if it primes straight away it would be the relay hope this helps
Old Aug 29, 2009 | 11:20 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
fuel pump relay, solenoid is either worn and not closing circuit, or the contactor is overheating and causing it to stick closed after use.
remedy, get a new one.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
tankybaby66
Aug 9, 2015 07:13 AM
tommylommykins
Ford Fiesta
Aug 8, 2015 08:01 PM
muz
Aug 1, 2015 06:48 AM
