Turbo on Endura DE lump
I'm looking to slap a turbo on my NA lump, just looking or a bit of advice as to weather I can even do it, and how to get oil lines to it.
Will there be any holes in the lump that are bunged up where turbo oil lines would normally go?
...yes, I am a bit of a noob when it comes to engine mods
This is in an escort van btw
Any help greatly appreciated.
Best bet would be to see if you can find someone with a turbo version to look at, failing that oil supply is easy as could always use oil pressure switch hole for supply if not other better one, and use a sump plug return.
I'd be more concerned about effects of boost control etc.
JK12
33
26-04-2021 12:09 PM
