Oil pressure/temperature sensors in my block
Wye Valley Hardcore
Can any one tell me what this sender/sensor is in my block? Is it for oil pressure or temperature or neither?
This is my turbo feed
oil pressure, don't know why they fitted 2. normally just done as per rst, screw the adaptor for the turbo oil feed into the existing pressure switch hole. what is that pipe thats blocked up where it looks the take off has been glued into the block using chemical metal?????
They both look like pressure switches, not big enough to be pressure sender for pressure gauge as they are generally a lot bigger.
Maybe the higher one was just used to plug a hole up ?, are you even sure the higher one is in the oil gallery, as it looks suspiciously like a block drain ?
DixieTheKid
11
06-06-2020 11:20 AM
Dr. Ickxs
15-09-2015 10:15 PM
mike elsome
14-09-2015 04:08 PM
Si B
12-09-2015 06:49 AM
