heated front screen
Old Dec 10, 2008 | 10:04 PM
turbomad'2008's Avatar
turbomad'2008
Default heated front screen
hello every one i have just joined up and was wondering if anyone one could help me ? i need to now what the colours of the wires are (i.e live negitive) its a heated front windscreen switch on my s2 escort rs turbo thanks
Old Dec 11, 2008 | 07:24 AM
I don't have a escort manula but will all be in a haynes manual, might be quicker ?, I'll see if I can borrow one just in case.
I assume it is not working ?, you do know that the engine needs to be running on these as the live output on the charge warning light wire energises one side of the relay.
Old Dec 11, 2008 | 05:06 PM
turbomad'2008
Default front screen
hi there thanks for the reply i didnt no the engine had to be runnin i will give it a try thanks damien
Old Dec 11, 2008 | 05:45 PM
Hi,
Yes pretty sure on these they do, they do on a a lot of cars, due to the large amount of current used, not all like it though.
Old Dec 11, 2008 | 05:53 PM
Thrush's Avatar
Thrush
Irritating c........
Yeah, nearly all Fords need to have the engine running otherwise the screen won't heat, and the light on the switch won't come on....
Old Dec 11, 2008 | 10:12 PM
turbomad'2008
THANKS ....
Old Dec 29, 2008 | 01:29 PM
alexst0ne's Avatar
alexst0ne
Does anyone know if an old shape Focus that doesn't have the heated front screen, actually has the wiring to the (non-existent) dashboard switch already there? My windscreen just started to split along the bottom for some reason and was thinking of upgrading....
Old Dec 29, 2008 | 04:31 PM
dangerousbrian's Avatar
dangerousbrian
mk4 escort will work the heated screen with just the ignition on...had to change the relay on my orion when it wouldnt switch on...they have some sort of timer that will automatically switch the screen off after a set time..it may just be that the relay is tripping out or whatever the technical term for it is..that is assuming that the orion and escort work the same of course
Old Dec 29, 2008 | 06:56 PM
Captain500rs's Avatar
Captain500rs
Right sorry to jump on the thread i have a saff and only the passenger half of my heated screen is working any ideas what it could be please ??
Old Dec 29, 2008 | 07:10 PM
stephenbatey's Avatar
stephenbatey
It`s fucked mate, just like mine
Old Dec 29, 2008 | 07:50 PM
Captain500rs
lol was thinking it might just be why wires behind windscreen pillar or summit like a fuse or something, If your driver sides works maybe wi could cut screens in half and use each others good bits lol
Old Dec 29, 2008 | 07:54 PM
stephenbatey
Sounds like a plan mate haha
Old Dec 29, 2008 | 11:58 PM
dangerousbrian
on a sierra the screen is in "2 halfs" if u get me...check to make sure the wires under the scuttle panel are earthed and check if they are soldered to the screen as they are quite weak..if they are ok then the screen is donald ducked...if u need a screen contact me or ask big ern and i will do u a good deal..that is if u dont go through insurance....hope this isnt breakin forum rules by the way
Old Dec 30, 2008 | 01:53 PM
Captain500rs
Is that the black plastic grill where the wipers live lol ?
Old Dec 30, 2008 | 04:16 PM
dangerousbrian
yes mate...of the top of my head i think you have to tke it off to get a proper look..if its original screen the connectors are sealed with a heat shrink type stuff...careful not to damage the wires..pretty sure they are bullet connectors...if you need any help giz a shout cause i think your local to me..am i right in thinking you got your car painted at erns?
Old Dec 31, 2008 | 07:16 PM
Captain500rs
Aye that's me matey
Old Mar 9, 2009 | 10:29 PM
turbomad'2008
Cool turbo timer ??
hi can anyone tell me how to fit a turbo timer on my escort rs how to wire it all up thanks
Oct 9, 2015 07:38 PM
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
YODI
Aug 30, 2015 01:12 PM
C2 MAK
Aug 20, 2015 09:46 PM
