Heater Problem
Old Dec 5, 2008 | 12:28 PM
Meadow's Avatar
Meadow
Default Heater Problem
Hi all, newbie here.
I have a 1996 MkV 1.6LX 16V Escort.
My heater isn't working, but the blower is, I'm just getting cold air which is no fun at this time of year. Haynes (spit) is no help at all.
It wasn't working last year when the head gasket went, but there were other symptoms then which haven't appeared this time. The car in itself is working fine.
Any thoughts as to the problem, and how difficult is it to fix? My technical skills about 2-3 spanners going by Haynes.
Thanks
Old Dec 5, 2008 | 04:57 PM
So long as you're sure the engine is getting up to proper temp, and the stat working as it should, feel the in out hoses as they go from the engine compartment through the bulkhead to the heater box, if they are both warm, then inside the car, have a look at the flaps to make sure they are moving when you operate the lever for vent/floor/screen etc, and also the hot/cold one, it may just be a cable off, worst it could be is a totally blocked matrix, but even this would still produce luke warm heat.
Old Dec 5, 2008 | 05:11 PM
Meadow's Avatar
Meadow
The flaps are certainly working, don't know if the heater dial is. Worth checking behind the dashboard then?
Hope it's not the matrix, that's beyond my skills.
Thanks.
Old Dec 5, 2008 | 05:30 PM
MAD Ade's Avatar
MAD Ade
Check your coolant level.
Old Dec 5, 2008 | 06:22 PM
I've never done a matrix on one of those escorts, but it's not as bad as it seems most heaters, just a lot of stuff to remove etc.
If you want to really scare yourself with a matrix try it on a rover sd1!!
Old Dec 10, 2008 | 10:10 AM
Meadow's Avatar
Meadow
Just to let you know, the problem is sorted in the short term. The pipes and matrix were furred up. My friendly mechanic pressure jetted the system and flushed it out with Radflush. Up to about 80% efficiency which will do for the moment.
I'll have to look at having the Matrix replaced in the summer, but at least I didn't have to shell out megabucks just before Christmas.
Thanks for your replys.
Old Dec 10, 2008 | 02:55 PM
If you put in some WYNNS cooling system cleaner, you most likely would not need a new matrix, but will have to clean the expansion tank out after 200-300 miles as all the gunge will settle there, as a jelly like mess, works wonders this stuff.
Old Dec 10, 2008 | 03:29 PM
Meadow's Avatar
Meadow
Thanks I'll remember that.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
