Ford Mondeo Y Reg
Old Dec 1, 2008 | 03:14 PM
limerick.123's Avatar
limerick.123
Default Ford Mondeo Y Reg
Can anyone advise me how to obtain a duplicate car key for my nephews new (secondhand car)? It's a Ford Mondeo Y Registration 2001.
Old Dec 1, 2008 | 04:53 PM
LHD220Turbo's Avatar
LHD220Turbo
i think the keys are coded so you'll need to go to any main dealer
Old Dec 1, 2008 | 06:37 PM
tarmac terriost's Avatar
tarmac terriost
take the key in to a dealer and they will read the key number for you it is done buy the depths of the cut on the brass bit ranging form 1-4 one is no cut and four is the deepest cut so can work it out that way,if the key is to worn will have to strip door lock down to get the number of the shims,if that is not possible do a vehicle lock set
the key will need to be programmed as it runs pats and will need two keys to do this
i know this as i work for ford in cornwall hope this helps !!!!
Old Dec 1, 2008 | 07:01 PM
limerick.123
Thank you so much for the information.
Limerick.123
Old Dec 2, 2008 | 04:44 AM
As above but shop around a lot, I did this on my mk1 with pats around 4/5 years ago, and for the supply of one black key, one red master key, keys programmed and all old keys deleted(was a repo car!!) cost ranged from Ł65 to Ł175, bet you can't guess which one I took!
Annoying this was as dealers were only 20 miles apart.
Old Dec 2, 2008 | 06:49 AM
dojj's Avatar
dojj
Resident Wrestling Legend
can you not do it with only 1 key then?
Old Dec 2, 2008 | 07:59 AM
limerick.123
All of this is so helpful. Thank you.
Old Dec 3, 2008 | 05:33 PM
With the red master you can programme the black normal keys, up to six I think.
Old Dec 3, 2008 | 05:59 PM
dojj's Avatar
dojj
only got one black one
and it's starting to wear out so i'm on the look out for a newer one, possiblythe jag key with it's fancy clip business
Old Dec 3, 2008 | 07:20 PM
limerick.123
He's only got a black key I'm sure.
M
Old Dec 7, 2008 | 03:59 PM
GUZZLER's Avatar
GUZZLER
if you don't have the red key then an autolocksmith would be the best bet, should be lot cheaper than a main dealer aswell.
Dojj, Greenford security services are not far from you, they used to do all that kind of stuff.
Old Dec 7, 2008 | 07:51 PM
limerick.123
Thank you. I shall pass this on and he can give it a cry
M
borboyous
Aug 22, 2015 11:17 AM
