cant get oversize bearings
Old Nov 24, 2008 | 08:42 PM
tooly80's Avatar
tooly80
tooly80
Default cant get oversize bearings
could anybody help me please,im having trouble getting new shell bearings, ive bought a 1.6cvh turbo block bored out to a 1.9 by power engineering. ive bin in touch with there surplier and he cant seem to get the oversize 1s i need.
Old Nov 24, 2008 | 08:45 PM
105epwr's Avatar
105epwr
have you tried burtonpower?
Old Nov 24, 2008 | 08:46 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
what size you after??
Matt
Old Nov 24, 2008 | 08:48 PM
tooly80's Avatar
tooly80
tooly80
Matt
0.4mm is the size on them,but i could bring them to you to look at as im not far from you.
Old Nov 24, 2008 | 08:49 PM
tooly80's Avatar
tooly80
tooly80
yeah they said they couldnt help me.
Old Nov 25, 2008 | 07:07 AM
B16CVH's Avatar
B16CVH
Are you after mains and B/E bearings? And are you saying that the crank has been ground to 0.4mm undersize or the bearing housings have been machined 0.4mm bigger?
Old Nov 27, 2008 | 03:55 PM
tooly80's Avatar
tooly80
tooly80
it is the ones between the crank shaft and block, everywhere is saying they are obsolete,
Old Nov 27, 2008 | 04:38 PM
tooly80's Avatar
tooly80
tooly80
ive bin told the best thing to do is to get a standard bottom end and have it bored out to suit my pistons,
Old Nov 27, 2008 | 07:09 PM
B16CVH's Avatar
B16CVH
So its the main bearings you are after. I know it says 0.4mm but is this reffering to the internal diameter of the bearings or the outside?
Reason i ask is that if is refering to the internal, then all you need to do is get the crank ground to -0.5mm. If its referring to the outside diameter then yes its easier to get another block.
Old Nov 27, 2008 | 07:46 PM
tooly80's Avatar
tooly80
tooly80
yeah its the outsideso im better off getting a cheap siezed block,thanks for the advice.
Old Nov 27, 2008 | 07:52 PM
B16CVH's Avatar
B16CVH
Oh tits. Block it is then!
tankybaby66
Feb 6, 2016 02:24 PM
89barto89
Oct 4, 2015 06:59 PM
fordrallycar
Sep 30, 2015 07:57 PM
20/20 vision
Sep 28, 2015 03:03 PM
dombanks
Sep 21, 2015 08:38 PM
