Having a few problems with carbs...
Old Nov 24, 2008 | 07:24 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Default Having a few problems with carbs...
I have a zetec on bike carbs which are setup for the engine.
but the car is running very bad, it only slowly revs and then bangs when you let off
all four carbs are getting fuel but what could cause it to rev so slow with a bang when i rev it to say 6k?
also theres hardly any pull at all.
any suggestions to these symptoms?
thanks
Old Nov 24, 2008 | 08:42 PM
105epwr's Avatar
105epwr
Hi
have you got a manual choke connected up?if not its not stuck on choke?
any air leaks?
or check that the needle diaphams have not split?
are they getting flat out on the throttle cable?
Old Nov 25, 2008 | 08:24 AM
By the sounds of it the mixture is well out, as in lean.
Are these carb's or throttle bodies ?, as a lot describe tb's as carbs.
Old Nov 25, 2008 | 04:50 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Originally Posted by 105epwr
Hi
have you got a manual choke connected up?if not its not stuck on choke? - no choke setup, but its not on
any air leaks? - none that i can find
or check that the needle diaphams have not split? - fine
are they getting flat out on the throttle cable? - yes
im completely stuck now, i might have to take it back to bogg brothers and ask them to have another look
i hope its not lean as its quite a drive to bogg brothers and if its too lean i might not get there....
might have another look for air leaks tonight.
thanks
Old Nov 25, 2008 | 05:43 PM
dunketh's Avatar
dunketh
Chief Iron Oxide Farmer.
Check timing too, although it'd have to be pretty far out to be that bad!
Old Nov 25, 2008 | 06:10 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
well im no further forward really,
if i pull the carbs up (they have abit of give on the silicone hoses) so there sitting at more of an angle to the engine, it brings the idle up abit, and its a smoother idle, but the throttle linkage doesnt move (so its not the throttle being pressed)
is that an air leak or do the carbs prefer to sit at that angle?
i couldnt find any leaks near the silicone hoses though.
thanks
Old Nov 25, 2008 | 06:39 PM
105epwr's Avatar
105epwr
thanks
can you rev it up from under the bonet (if you remove air filters)and see all the needles lifting up equally?
are you running a fuel filter?could have drawn sum shit in carbs?
fuel pressure ok?
prima racing have stuff to do with bike carbs aswell if thats any nearer(in nottingham)
they normally sit at an angle (upwards)but the bowls are straight and controlled by the floats to ensure fuel delivery constantly!
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
