heater problem
Old Nov 21, 2008 | 01:37 PM
ikarma70's Avatar
ikarma70
Default heater problem
having heater trouble in my little fiesta.
theres no misfire or sludge in the coolant tank/oil filler cap and the temp gauge never gets past 1/4 of the temp scale so that rules out HGF.
apparently the fords are known for this...what could be the problem?
thanks in advance
me
Old Nov 21, 2008 | 01:59 PM
B16CVH's Avatar
B16CVH
Replace the thermostsat for a start
Old Nov 26, 2008 | 04:41 PM
cabriolet's Avatar
cabriolet
change the thermostat backflush the heater matrix
Old Nov 26, 2008 | 04:56 PM
Before you change stat and anti freeze, I would run around for a few hundred miles with WYNN's cooling system cleaner, it gets out every last bit of crap out of there, and will leave it in the bottom of the expansion tank in a opaque gel like substance, but god it works so well.
Then new stat/a,freeze and if still reading low a temp sender, mine always shows low about 1/4 even with new stat etc, though if it sits in traffic and goes up to about 3/4 it will generally stay there for the rest of the day.
Old Nov 26, 2008 | 05:04 PM
G Beale's Avatar
G Beale
What kind of trouble are you having exactly bud ? If it doesn't blow hot then chances are it's the "heater control valve" under the wipers that's knackered (if your car has one ?). £20, an hour to replace, google it.
Old Nov 27, 2008 | 01:40 PM
dangerousbrian's Avatar
dangerousbrian
im having similair problems...apart from my temp gauge goes up stright after starting the car frm cold..the heaters blow warm straight away and the water in the header tank is cold...ive put new anti freeze in and a 82 degree thermostat..gonna change the temp sensor also..any ideas? everything was working fine before i took it off the road.can temp sensors knack up after sitting for 18month? cheers
Old Nov 27, 2008 | 02:12 PM
ikarma70's Avatar
ikarma70
that is exactly what the problem was,the solenoid on the heater valve was knackered.
i connected the new part up and it worked perfectly with a good click then tried the old unit and it was silent.
got a nice warm toasty fiesta now
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
