S2 brake problems
Old Nov 16, 2008 | 11:55 AM
S2 Craig's Avatar
S2 Craig
Angry S2 brake problems
Hi,
Just replaced rear brake pips on my escort and replaced the master cylinder with a patent lucas cylinder, cant seem to get a good pedal. Keep bleeding it, pedal pumps up but when leaving and re-applying it goes straight to the floor. I have tried 2 master cylinders, these master cyliders have 4 ports. I have blocked off 2 of them cos I am still running with the standard abs. Am thinking maybe I should try and genuine master cylinder, itdoesnt seem to be pushing that much pressure.
PLEASE HELP!
Old Nov 16, 2008 | 12:04 PM
B16CVH's Avatar
B16CVH
You need to bleed the brakes with the back wheels on the ground if you have the brake proportioning valves on the rear!
Old Nov 16, 2008 | 04:46 PM
S2 Craig's Avatar
S2 Craig
ye, ive got the rear wheels on the ground, and i can see the valves operating. i am getting fluid out the back, but i would like to see more presure.
if u think the cylinders rite, do u think it could be somthin to do with the ABS.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
