Starting problem
Old Nov 7, 2008 | 07:35 PM
BRIAN3375's Avatar
BRIAN3375
Default Starting problem
Hi can anyone help? I have a s2 rs turbo and i have a problem trying to get it started after it has been running. It is like it has a flat battery but once it has cooled down it starts no problem. Any ideas ? Thanks..
Old Nov 7, 2008 | 08:32 PM
3iturbo's Avatar
3iturbo
i had same prob the wires that go to the starter motor are getting hot......try and put the wires away from the exhaust .or make a heat sheild for the starter and the wires...sorted
Old Dec 4, 2008 | 06:45 PM
luke_rsfesta's Avatar
luke_rsfesta
it always needs something
i had the same problem on myfrst i ended up buying a new starter motor cus i already had the heat shield and covered my wires so in the end it was the starter motor,been fine ever since.sorted
Old Dec 5, 2008 | 07:34 AM
Defo sounds like a starter problem with excess heat, thought these had a shield as std ?
Old Dec 5, 2008 | 11:41 AM
B16CVH's Avatar
B16CVH
I had this same problem but it wasnt the starter, soon as i changed to coz mgmt i never had the problem again so i put it down to the metering unit maybe? Would start brilliant from cold, pop to the petrol station to fill up then i would need to sit ther like a twat for ten minutes till the bastard cooled down slighlty, it turned over as sweet on the key also.
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
muffster
13
Sep 3, 2015 09:40 PM
nick8saff
Aug 16, 2015 05:35 PM
Sjieter
Aug 5, 2015 09:47 PM
