mk5a RS2000 running problems
Old Nov 5, 2008 | 07:23 PM
bazilbrush005's Avatar
bazilbrush005
Default mk5a RS2000 running problems
Hi
Can any one help me i have an RS2000 my second one but i can't get this one to run properly,from cold she will tick over touch the throttle and it will stall.Once you have a bit of temp in it you can rev her but she stutters and misfires up to 4000 revs and thats it she will go no higher,the plugs get an oily sooty black colour.So far i have changed the coil packs,ht leads and plugs the wiring harness that plugs into the coilpacks had all the insulation pulled off the wires and just taped up by some plonker before i owned her so i cut the exposed wire out and repaced with new wire and heat shrinked the connections but she still cannot rev correctly,I'm compleatly out of ideas can anyone help please.Don't hesitate to contact me at baz1lbrush@supanet.com for a more direct contact cheers.
Old Feb 16, 2010 | 03:12 PM
Dursley's Avatar
Dursley
lambda sensors
Pwrs2k
120
Oct 16, 2015 03:16 PM
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
