rolling road graph analysis
Old Nov 2, 2008 | 07:42 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Default rolling road graph analysis
Been to the rolling road at APT today to find out how many ponies went missing after rebuilding my head.
On the outset, things look good! It's no worse than it was before (unless 4bhp counts ), but slightly annoying is that it's no better. In fact, it looks like I put it together right, which I'm more proud of!
Made 236 at the flywheel, which was a bit pants, and, that naughty fuelling problem is back again. In fact, it's now leaner than it was before.
My simplistic understanding of the situation is that as the head's now actually flowing some gas, it's naturally got more air going in than fuel, so as it was 'ok' before, it's going to be lean now.
Graphs are below for advice, opinions, and general analysis:
Old Nov 3, 2008 | 01:48 PM
You already know what part of the problem may be but chose not to fix it, you have to do all the basics first, but pointless telling some people, you killed two new headgaskets, because you didn't want help, well from certain people anyway.
Speaking of rolling roads, I was drooling over gooeys car today at Emerald, and having a gas about it, very well prepared car it is.
Old Nov 3, 2008 | 04:32 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I killed two head gaskets because I was a numpty and didn't remove the 2nd heaviest part of the head, ie the turbo, and because I was too eager to get it done. Lesson learned, albeit the expensive way.
Thanks for replying though - it's more than the other 42 viewers of the thread have done, with the exception of those who've posted on the Norfolk group's forum.
Old Nov 3, 2008 | 04:36 PM
Stu @ M Developments's Avatar
PassionFords Creator
What do you want analyzing? I dont understand your question to be honest, and i think the other readers are the same.
Old Nov 3, 2008 | 05:00 PM
cozmeister's Avatar
cozmeister
More boost Igor!
I hadn't thought of that...I feel a bit of a plum.
I've read my post again and I don't understand what I was trying to ask either. I'll come back when I've worked it out.
Old Nov 3, 2008 | 05:41 PM
Christian and Beccy's Avatar
Christian and Beccy
#1 in Spelling Club
You were probably going to ask possible causes for the fuelling leaning off in the higher RPM's. Aside from my suggestions of tired fuel pump, incorrect fuel pressure, tired injectors, insufficient headroom in injectors etc etc.
Old Nov 3, 2008 | 06:32 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Nope I do believe you! Suffice to say I'm not going to fiddle with it any more - gonna leave it to the experts. It may well be spending an extended holiday with you if you'll have it
Old Nov 3, 2008 | 11:42 PM
bigstee1's Avatar
bigstee1
get it down to stu and kenny at msd as you say leave it to the experts
Old Nov 4, 2008 | 01:01 AM
He's allready had it over at APT and they are great tuners. One of the very few i would let work on my own cars.
Old Nov 4, 2008 | 12:39 PM
It's got a new pump(941) pressure has been checked and was bang on.
Cozmeister is still on the old wiring though, which is why I suggested(last year) a check of pump voltage under load, and said just bring it round and I'll rewire it FOC, but it's up to him.
Old Nov 4, 2008 | 01:44 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Well it ain't going anywhere for the time being as it just failed the MOT
CO was 3.3%, and HC was 310, so for a change it passed on the emissions (just!). I'll be happy to take you up on the offer tabs....once I get it back anyway!
Old Nov 4, 2008 | 04:21 PM
Did it fail bad then ?
I am at two RR sessions next week(complete mapping) for two diferent cars(two different places) if you want to tag along to one ?
The rewire won't take long to do, if you want we could always put an extra fuel cut out switch in at the same time ?
Old Nov 4, 2008 | 05:52 PM
cozmeister's Avatar
cozmeister
More boost Igor!
2 hours of welding, really that's it. Just annoying - as well as a couple of other things that I could've sorted myself if I'd have thought about it and not been lazy. My own fault but hey ho.
Should have it back tomorrow, so whenever you're free.
Old Nov 4, 2008 | 05:53 PM
cozmeister's Avatar
cozmeister
More boost Igor!
Old Nov 4, 2008 | 07:27 PM
The dreaded tin worm strikes again!!
Not bad though, could have been a lot worse, should be able to on the 15th(nov), got to change my tank, put on pre filter, pump(044) and new filter, and a few other bits, scorpio cossie rear roll bar, solid diff mount, solid beam mounts, solid rack bushes, and a new gauge set.
If you are interested in the I14 engine/box, you need to shout soon, it's FOC, just needs picking up, bro has changed his plans, selling whole kit car now as just bought new Cayman.
boeb
Jan 9, 2020 05:11 AM
mk22door
23
Oct 2, 2015 10:06 PM
AJC
Oct 1, 2015 06:47 PM
Mikersturbo
Sep 27, 2015 07:43 PM
