Is my heated front windscreen working?
Old Nov 14, 2004 | 11:00 PM
Ghia19's Avatar
Ghia19
Default Is my heated front windscreen working?
Hi there,
I have a fiesta MK4 '96 Ghia. It has a heated front windscreen. Now with it being the autumn months I am having to use my rear and front windscreen heaters.
However I don't think my front is working, I never see an effect from it unlike the back. So I've checked the haynes manual and checked the fuse, which happens to be fine.
Ok so, how do I actually check that the front heated screen isn't working, and if it isn't, what could the problem be?
And I assume the front and rear work on the same switch, because I only have one...
Old Nov 15, 2004 | 12:08 AM
AJ Escos's Avatar
AJ Escos
front should work of a separate switch m8
Old Nov 15, 2004 | 12:09 AM
AJ Escos's Avatar
AJ Escos
pull one of the front pillar trims off and see if its connected to anything
Old Nov 15, 2004 | 08:11 AM
ghia199's Avatar
ghia199
Hi, it's Ghia19.
Erm I only have one switch and that operates the back... The front screen definatly has heater strips and being a Ghia.... Hmmm, why would there be no switch???
I'll try looking behind the blanking switches..
Old Nov 15, 2004 | 02:53 PM
Ghia19's Avatar
Ghia19
Well, i've just had a really good investigation and...
There is no front window switch, there is no wiring to the switch, all there is are the connector tags to the front heated screen!!
This is a Ghia model, which is supposed to have a heated front screen? Well the screen is heated, there's just absolutly no circuitry to the screen!!
How can i fix this?
Old Nov 17, 2004 | 12:03 AM
AJ Escos's Avatar
AJ Escos
to be honest m8 not sure how you would fix it exactly, but im sure a simple bit off wiring should have it working,try asking in the general section m8 as more will see it
Old Nov 18, 2004 | 07:14 PM
SteveB's Avatar
SteveB
You need an auto electrician/someone who knows what they are doing to wire it up to the std ford switch if you have 1. I'd have thought it'll be no more than ahours job for someone whos competant
Old Nov 18, 2004 | 08:13 PM
Dave Henshall's Avatar
Dave Henshall
similar thing to my old rs1800 festa - sold without ABS, when looked properly it obviosly did have the pumps under the bonnet and the piping, turned out ford had fitted the warning lamp in the glow plug on indicator in the dash -
Old Nov 19, 2004 | 04:38 PM
Moonie's Avatar
Moonie
A quick test to check if you heated screens are workin is to see if the rpm dips when you turn them on because of the extra load on the alternator
Old Nov 20, 2004 | 09:45 AM
Dave Henshall
yep - but if now wires are connected to it - pretty sure it wont work anyway ...
Old Nov 20, 2004 | 01:04 PM
Moonie's Avatar
Moonie
lol true
track.focus'd
Aug 12, 2015 05:53 PM
Red_bull
Aug 9, 2015 08:34 AM
Old ford
Jul 31, 2015 06:50 AM
