mk3 and mk4 wiring
Old Oct 26, 2008 | 10:48 PM
danny_boy699's Avatar
danny_boy699
chatter 4 life
Default mk3 and mk4 wiring
can any 1 help i changing the wiring plug on my mk4 loom to mk3 for lights and wipers but mk4 has more wires and diffrent colour any 1 got a idea witch wire goes where and what color thanks danny
Old Oct 27, 2008 | 11:24 AM
JesseT's Avatar
JesseT
What for? The circuit for lights for instance is hugely different with mk4 using a lot more relays.
Old Oct 27, 2008 | 05:43 PM
MarkN's Avatar
MarkN
I've done this - and its not easy. The Mk3 used most directly switched stalk circuits whereas most of the Mk4 ones are relay switched. You also have problems with the indicators as the Mk4 fuse box has no provision for the flasher relay, and with the horn IIRC as the Mk3 uses a switch on the +ve side and the Mk4 a -ve.
Its not just a matter of matching up the colours. If I get time I'll write down exactly which Mk3 colours match to which Mk4 colours. I did get it all working in the end including the variable wiper delay and the auxilliary warning lights.
Old Oct 28, 2008 | 02:41 PM
danny_boy699
chatter 4 life
cheers fella if u can
Old Oct 30, 2008 | 06:13 PM
moesin2005's Avatar
moesin2005
just put a mk4 loom in my series 1 pain in the arse found the clocks easyest to do though but would love to no how to get the different wiper speeds
Old Oct 30, 2008 | 06:16 PM
moesin2005's Avatar
moesin2005
plus seem to have trouble with gettin the hand brake light to work but i found the indecators wored okby joining the blk/violet and the blk/green together
Old Oct 31, 2008 | 12:27 AM
danny_boy699
chatter 4 life
any idea how the wiper and idny wires go mate, been told of other people you have to put a reley in for the indys
Old Oct 31, 2008 | 06:28 PM
moesin2005's Avatar
moesin2005
mine has some relays for the horn indys and lights but on the lights we cut one of the earths to the bulbs and fitted it to the bodywork
moesin2005's Avatar
moesin2005
JasonPD
Ford Focus RS
20
Oct 31, 2015 08:11 PM
liamT74
Sep 23, 2015 10:24 PM
bassboy
Sep 10, 2015 08:54 PM
sunburstred
Sep 9, 2015 11:24 PM
imnoteasy
Sep 7, 2015 09:26 PM
