wiring a switch
Old Oct 25, 2008 | 01:12 PM
RUBY123's Avatar
RUBY123
Default wiring a switch
hello hers one for people who are good with electrics. I've got a switch that when you hold it down it activates whatever its connected to and when you let it go it disconnects. is there a way with relays or what ever to keep it connected when you let go of the switch thanks in advance
Old Oct 25, 2008 | 01:19 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
are we talking 12v or 230v bud
Old Oct 25, 2008 | 02:23 PM
RUBY123's Avatar
RUBY123
oh sorry 12 v
Old Oct 25, 2008 | 02:34 PM
e30cossie's Avatar
e30cossie
E36 cosworth
Not being funny can you change the switch to a different type ?
Old Oct 25, 2008 | 02:41 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
i wouls say change the switch for what it is worth
Old Oct 25, 2008 | 05:31 PM
YES there is a way, but easier to change the switch.
If you still want to go ahead with this switch, you would need to put a latch on the relay, then add another switch that is also momentary like your present one but normally closed, whereas your one is normally open.
Much simpler just to get another switch but yes it can be done.
Old Oct 25, 2008 | 05:55 PM
RUBY123's Avatar
RUBY123
thanks all for your help so far. i no it would be easier to change the switch but some one has previously put this particular switch in the dash and it would be handy if i could use this particular switch for this application. if worst comes to the worse I'll get a switch and put it some were else
Old Oct 26, 2008 | 08:52 AM
Just put through a relay then with a latch, and put a momentatry switch(normally closed) in the latch, so you just press this for off.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
