co level too high.
Old Oct 7, 2008 | 06:41 PM
swettyring's Avatar
swettyring
Unhappy co level too high.
as title,co level is @ 4% and cant adjust it any lower on the potentiometer,i can adjust it richer but not lower than 4%.i took this engine and ecu out of my transit that i had and all was ok in there.it runs ok but there is a slight misfire on full throttle.i've fitted new 071 plugs,decent leads etc aswell as a fse boost valve which is set up spot on.run out of ideas except for changing the ecu which i'll try in the next couple of days.any suggestions?
Old Oct 8, 2008 | 04:33 AM
Get rid of the FSE first, or just turn down the fuel pressure.
Old Oct 8, 2008 | 07:44 AM
swettyring's Avatar
swettyring
i've turned the pressure down to 2.8 bar without vacuum,which does lower the co a bit,but still cant achieve a figure even close to what it should be.whats wrong with the fse valve?ford dont sell original ones anymore.
Old Oct 8, 2008 | 02:21 PM
You don't need a ford one just a decent one, seen a few fse give this exact problem, where the rail pressure keeps altering, can even happen to older ford ones.
I changed mine today for a RS500 one on me sapph, as had fluctuating fp, perfect now, cut ring off around old one and took bits out, there was a small spring inside with a pintle on the end that was broken, but main spring and diaphragm was ok.
Have you looked at CTS value ?
Old Oct 9, 2008 | 12:13 PM
swettyring's Avatar
swettyring
the fuel seems to keep a constant pressure,though i'm not dismissing this and will try another valve just in case.also what is the cts value?
thanks.
Old Oct 9, 2008 | 07:31 PM
costina's Avatar
costina
Live long and prosper!!
Coolent temp sensor located rear rhs of head its the blue one
Try this site
www.bigturbo.co.uk
Paul
Old Oct 10, 2008 | 08:03 AM
swettyring's Avatar
swettyring
wow,there's some cool info on that site,thanks.as for the cts,if i disconnect it,it runs really rough,what value am i after?a voltage?
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
IainRS1700T
Sep 25, 2015 06:44 AM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
little bram
Sep 21, 2015 02:50 PM
