noisy gearbox in neutral please help.
Old 28-08-2008, 06:50 PM
cosworth_wannabee
cosworth_wannabee's Avatar
Default noisy gearbox in neutral please help.
ok, need help bigtime as i want this car on the road next week!! so please help me
its an xr 5 speed on a 2.0 zetec in a mk4 escort. whenever the clutch is up it makes a horrible clattering and squeeking in neutral, when clutch is pushed in or in gear no noise.?!?!
anyway originally it needed a gearbox change as synchro in 1st had gon and kept popping out and it was noisy, so i replaced the box assuming both problems would go... but they didnt, the noise is still there.
had a lok in haynes book and it says something about input shaft bearing?!?!
thanks in advance for any help
Old 28-08-2008, 06:54 PM
Brian
Brian's Avatar
Sounds like its the release bearing mate
Brian
Old 28-08-2008, 06:58 PM
picky775
picky775's Avatar
What he said^^^^
Old 28-08-2008, 07:05 PM
cosworth_wannabee
had a look in haynes book and thats the actual arm that depresses the clutch right, so when the box was changed that would have been inside the box yeh??? whats the chances of them both being fucked#? cheers
Old 28-08-2008, 08:30 PM
northernmonkey
I didn't do it!
northernmonkey's Avatar
if your gonna have the gearbox off, you may as well do all 3, clutch, plate and release bearing, then you know it's right!
Old 28-08-2008, 09:00 PM
Rax
Rax's Avatar
2nd that,did you use new release bearing when changing box ? i would as matter of course while box is off
Old 29-08-2008, 04:32 PM
xrmalin
xrmalin's Avatar
the bearing there talking about isnt actualy inside the gearbox its part of the clutch assembly so when you had the box changed they probably used the one that was already in your old box hence why its still noisey.
Old 29-08-2008, 09:04 PM
Cozziekid
Cozziekid's Avatar
The way you have explained it, sounds like the input shaft bearings are fooked (noisy when clutch is released quiet when clutch is pressed)
If it was the thrust bearing it would be the other way round (noisy when clutch pressed, quiet when released)
Old 29-08-2008, 09:10 PM
D16PJM
D16PJM's Avatar
lay shaft or release bearing either way the box has got to come out so you can check the shaft then
chowfornow
14
05-01-2019 09:01 PM
mjonathan24
29-10-2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
Iain Mac
30-09-2015 09:39 PM
muzzman1
30-09-2015 08:59 PM
Quick Reply: noisy gearbox in neutral please help.
