Standard Cossie Fuel Pressure
Old Aug 25, 2008 | 07:37 AM
AdamB's Avatar
AdamB
Default Standard Cossie Fuel Pressure
Could anybody tell me what fuel pressure a standard saph cos runs please?
thanks
Old Aug 25, 2008 | 07:42 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
3 bar
Old Aug 25, 2008 | 07:49 AM
Kverna's Avatar
Kverna
Virgin-popper
3Bar, 3,5bar without vacuum or something
Old Aug 25, 2008 | 08:27 AM
AdamB's Avatar
AdamB
ok thanks
perfect for what i needed the info for
Old Aug 25, 2008 | 08:48 AM
3 bar vac pipe on, around 3.5 with pipe off and plugged, in practice though around 3.7/3.8 bar with pipe off
Old Sep 13, 2008 | 09:45 AM
AdamB's Avatar
AdamB
thanks
basically wanted to know as i have some braided fuel hose for my mk4, and needed to make sure it was up to the job
its the same as a mate is running on his cossie
my pressure reg is set at 3.5 bar, so should all be ok
Old Sep 13, 2008 | 11:57 PM
Stu @ M Developments's Avatar
PassionFords Creator
The correct answer is 3.5 bar with the pipe off.
The pipe ON figure is pretty meaningless as it depends on manifold depression. The pipe OFF figure is a constant and the only one that should be used to determine fuel pressure.
Its also worth bearing in mind that it MUST raise with boost in a linear 1:1 fashion.
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
Zoggon
Aug 10, 2015 10:39 AM
