1.8 zetec splutter
Old Aug 21, 2008 | 07:17 PM
fonfe's Avatar
fonfe
Default 1.8 zetec splutter
1.8 zetec that i used tp have in my mk4 escort and was beautiful the whole tim eit was in there, took it out and put it into my fiesta si as the head was warped on the si, was running fine (never drove it though as it was staying at work) only probelm with it was that it seemed to be overfueling a great deal and when i removed the cat when putting the engine in a lot of it well erm fell out so to speak!
so in light of it overfueling i figured ok im still running the 1.6 lambda sensor il swap it for the 1.8 one i had in the escort. did this and it didnt really seem to change much. but as the engine got hotter it started to missfire when reved untill unless you really gently pushed down on the throttle really slowly it would just cough and splutter then cut out.
im thinking possible blocked fuel filter, as the demand for fuel will increase a lot quicker if just bliping the throttle sharply rather than really slowly and progresivly raising the revs.
also came across a plug that i cant for the life of me remember where it went!
car is running external EDIS. if you follow the crank sensor wires they take you up to a larger multiplug and the mystery plug is the only other plug thats in the loom up to the multiplug to then connect to the EDIS module.
anyone got any ideas?
Old Aug 21, 2008 | 07:52 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
The HEGO (lambda) sensors will be the same, although I guess one could be on its way out and the other not (or partly).
Old Aug 21, 2008 | 10:47 PM
fonfe's Avatar
fonfe
Yeah but the one that's in it is a known working one as it was running fine in the escort?
Old Aug 22, 2008 | 05:22 PM
fonfe's Avatar
fonfe
ok well swapped back to the original lambda sensor that was in the fiesta andstill no sucess, checked the wiring to the fuel pump and that has a good feed with a strong earth so am no kinda stumped! ive got spare coil pack and maf at work so am going to try that tomorrow
Old Aug 23, 2008 | 05:27 PM
fonfe's Avatar
fonfe
no worries i sorted it
Old Aug 23, 2008 | 05:48 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Well................ what was it?
mk3ste
Oct 17, 2021 10:09 AM
timsrs
Nov 13, 2018 11:48 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
mondeomark
Sep 28, 2015 06:28 AM
