blue smoke after service on frst
Old 17-08-2008 | 11:21 AM
kieran265's Avatar
kieran265
Default blue smoke after service on frst
hi i serviced my fiesta rs turbo today and after filling with oil changing plugs and fuel fitler i started it up and it smoked quiet bad until warm.
i havent over filed with oil and i used castral magnetic 10w.40.
could this b valve stem sills or sumin else?
thanks kieran
Old 17-08-2008 | 12:30 PM
denbo's Avatar
denbo
Could well be the valve stem oil seals but after that it maybe the turbo seals in the turbo gone .
Old 17-08-2008 | 09:33 PM
ScORTED's Avatar
ScORTED
Project Money Pit
did you remember to repressurise the turbo before firing it up by turning it over with the leads off?
Old 17-08-2008 | 10:43 PM
kieran265's Avatar
kieran265
i think i have an air cooled turbo but may b wrong.
i didnt relise i had to do that to the turbo, so would that make it smoke? and could it b the oil as i was told today that could b the wrong oil as i used 10w/ 40 but told i was ment 2 b 5w/30
thanks kieran
Old 18-08-2008 | 07:59 AM
He is reffering to the oil side of the turbo, but you are right it is totally unecessary to do this, if it has been off for months/years then yes a good idea.
Most likely a combination of worn stem seals and or worn turbo, not seals in the turbo as they don't have any, check your breather system is nice and clear, depending on what oil it was on before the new oil could be thinner so will smoke/use a little more, if someone had a 60 weight in before for example.
The oil you used is slightly thicker than the 5W30 that you say it should use, I have never used 5W30 as simply too thin the way I drive.
The fact that is burns oil shows there is oil there so don't know why someone suggests there isn't, of course lack of oil cannot make smoke as there is no oil to do it!!
Some turbos are water cooled others aren't, on some cars you can take the water cooling off without problem, but others not.
S1 rst did not have water cooling on turbo, but S2 rst did for example.
Old 18-08-2008 | 03:24 PM
kieran265's Avatar
kieran265
would it b safe to put 20w/ 50 in the frst or is that too thick, it never smoked b4 the service so i cannot under stand y it is now!
very frustrating and embarasing
thanks kieran
Old 19-08-2008 | 06:09 AM
50 weight is a bit thick but when engines are worn, they sometimes need it, but keep the first number lower, ie 5W50 is better than a 20W50 as it is thinner at lower temps so helps starter and is better as too thick an oil will/may lead to sluggish tappets until oil temp is up and it naturally thins out a bit.
tankybaby66
06-02-2016 03:24 PM
01-11-2015 07:53 PM
DAZZER
30-09-2015 09:43 PM
Fudgey
21
30-09-2015 07:19 PM
Quick Reply: blue smoke after service on frst
