Replacement Gearbox for ST200?
Old Aug 14, 2008 | 11:09 PM
djleeroy's Avatar
djleeroy
Exclamation Replacement Gearbox for ST200?
Hi, I'm thinking of replacing the gearbox in my ST200 as it's done 104k and starting to feel a little tired and notchy....
Firstly, I intend to fit a new clutch while I'm at it. Is the ST200 any different from the other 2.5v6 models in the range (ST24, Ghia X etc etc)?
By that I mean will any 'box/clutch from a V6 fit?
Secondly, where can I get a decent 'box from that won't cost the earth (i.e. FoMoCo!) I have found a clutch for about £150 (reasonable?)
I'm based in Berkshire if that helps...
I know it's long winded but you guys have been fantastic for me so far and this time i'm really stuck!
Any help at all would be much appreciated..
Lee.
Old Aug 14, 2008 | 11:22 PM
anodised's Avatar
anodised
i think any v6 box will fit poss even a st220 the cougar is the same gearbox aswell
and the later st220 come with 6 speed
Old Aug 15, 2008 | 07:01 PM
djleeroy's Avatar
djleeroy
Really? Can anyone confirm this? The gear box needs to come out when replacing the clutch so would be a perfect oppertunity to upgrade!!!
Old Aug 18, 2008 | 10:24 AM
bookwyse's Avatar
bookwyse
The 220 six speed is not a straight swap as it uses a diffrent size input shaft.
Whilst any of the boxes from the V6's will fit they are not the same as the 200 uses diffrent 5th gear ratios to make the most out of the car.
Old Aug 18, 2008 | 07:26 PM
djleeroy's Avatar
djleeroy
Bummer... Thanks anyway though...
Now to source an ST200 gearbox!
krypton
Sep 23, 2015 07:29 PM
Shaunc
Escort Range
Sep 22, 2015 06:38 PM
NC53
Sep 13, 2015 03:05 PM
Adam Graham
Sep 6, 2015 06:04 AM
gingeRS
Sep 4, 2015 06:29 PM
