1.8 deisel to RST power!!!
Old Aug 10, 2008 | 10:15 PM
technixcars's Avatar
technixcars
Default 1.8 deisel to RST power!!!
Hello people!! new to the site so hello!
Right, ive had a 1.8 deisel van for about a year now and getting pretty bored of the 'sluggish' power. ive recently purchased an escort rs turbo engine and all the wiring loom, you can pretty much guess the question
is there anything major ill need to change other than the fuel tank??
also what to do with wiring the RS loom to the van??
any help would be much appreciated!! thanks!!
Old Aug 11, 2008 | 07:08 AM
Dzish's Avatar
Dzish
I have escort van diesel too. Sory mate but that is all power you can ever had from that engine 1.8 diesel is 44 KW, or 1,8 TD is 65 KW. It isnt made for race, or fast sprints, but is very economical, and saving a lot of fuel comparing with RS. + gerabox of vans is a little modificated (comparing with normal cars) so he can moove easy a lot of weight.
Old Aug 11, 2008 | 06:52 PM
ScORTED's Avatar
ScORTED
Project Money Pit
sluggish, its more like an iceage... what you want is a 2.1 zvh pushing 250bhp...
might dent your fuel economy though
Old Aug 11, 2008 | 07:40 PM
peachy's Avatar
peachy
For the full conversion your looking at:
Engine
ECU
Radiator & fan
Intercooler
Turbo unit
Wiring Loom, engine or full
Plenuim chamber
Boost hoses
Water Hoses
Exhaust
Air/Fuel Metering unit
Fuel Tank
Fuel Pump
Fuel Accumulator
Fuel Lines
I have most of these parts on the shelf but its a costly way to do it. Youd be better picking up a breaker ERST.
If you need the parts you know where i am! I would also reccomend changing the gearbox to a LSD one, which i also have handy
I done a full cabrio conversion and this was the minimum of parts i used.
Old Aug 11, 2008 | 11:03 PM
technixcars
thanks for the input people much appreciated, luckily enough i have a complete RS turbo to use for parts so swapping parts needed wont be a problem, as for wiring the RS loom into the van, anyone know what is required for that side of things??
Old Aug 11, 2008 | 11:56 PM
ScORTED's Avatar
ScORTED
Project Money Pit
naff all just use the rs engine management loom complete, then wire up the rev counter etc and the oil pressure switch etc
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Iain Mac
Sep 30, 2015 09:39 PM
