turbo advise
Old Aug 4, 2008 | 02:52 PM
mikedaf2's Avatar
mikedaf2
Default turbo advise
just wondered if a t34 with 360 degree kit and 0.63 exhaust housing would be big enough to coupe with 30psi for 500bhp
Old Aug 4, 2008 | 02:54 PM
KSA-Cossie's Avatar
KSA-Cossie
Not a hope in hell,will just scrape 400 bhp.
Old Aug 4, 2008 | 07:44 PM
mikedaf2's Avatar
mikedaf2
thanks mate as suspected the reason i ask is because i currently have a t61 on the car and i am getting turbo surge. i have tried taking some ignition timing away and it has made no difference any ideas anyone?
Old Aug 4, 2008 | 07:49 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Yeah, make the head flow better.
Is it a proper T61, or some t3/t61 hybrid crap?
Old Aug 5, 2008 | 04:39 AM
Check you have suffecient fuel at the surge speed.
Old Aug 5, 2008 | 10:30 PM
mikedaf2's Avatar
mikedaf2
Thanks i have checked i have sufficient fuel it is lambda .80 at the point of surge and the head is ported to 25mm inlet and 24mm exhaust. I have noticed that the 500 style cooler has 62mm connections but the turbo and throttle body are 72mm. i am wondering if this may be causing a restriction?
Old Aug 6, 2008 | 05:41 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
No..
Matt Baxter
Sep 16, 2015 08:30 PM
Bailes1992
Sep 3, 2015 02:17 PM
borboyous
Aug 22, 2015 11:17 AM
Bailes1992
Aug 16, 2015 07:14 PM
Michael Wisbey
Aug 14, 2015 11:57 PM
