CVH crankshaft
Old 29-07-2008, 04:33 PM
irsq4
irsq4's Avatar
Default CVH crankshaft
Can I use 1.8 CVH crankshaft (stroke 88 mm) in 1.6 CVH (stroke 79.52 mm) engine block. (Sierra)
Old 30-07-2008, 10:57 AM
bob_series1
bob_series1's Avatar
Default C/R
I would say the answer is no as this would change the C/R by a huge amount if you intend on using the 1.6 pistons ECT....
Old 31-07-2008, 04:16 PM
Turbo Zetec
Engine Machinist
Turbo Zetec's Avatar
i believe you can, but i'm sure it requires mods to the inside of the block for clearance.
mk3ste
17-10-2021 10:09 AM
jessie_rs
62
06-08-2019 09:27 PM
07-10-2015 12:56 PM
sridgett
13
27-09-2015 06:03 PM
Russp
Escort Range
18-09-2015 07:39 PM
Quick Reply: CVH crankshaft
