escort mk5 best value brake upgrade
Old 12-07-2008 | 06:58 PM
burnzy's Avatar
burnzy
burnzy
Default escort mk5 best value brake upgrade
i'm already gunna bolt an rs2000 rear beam to my mk5 1.4, atm escort , i was wonderin wot is the best option for the front, i don't wanna spend megga money, n some second hand 4pot 2wd sierra cosworth calipers n disk's have taken my fancy cos the calipers will look nice through 5 spoke compo's will they bolt on or is there a better option, cheer's for the help lad's, once some cash comes through my project will start to kick off properly n will post some pic's up on the restoration forum, to show how all your advice has helped me out
Old 13-07-2008 | 03:05 PM
fonfe's Avatar
fonfe
cheapest would be the mondy v6 front setup
Old 14-07-2008 | 03:18 PM
Ollie MK5 Turbo's Avatar
Ollie MK5 Turbo
That or Escort cosworth are about the same.
Old 14-07-2008 | 06:09 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Put RS2000 ones on the front to match your rear setup.
Just be aware that your master cylinder may no longer be up to the job.
Old 16-07-2008 | 10:47 AM
danrs2k's Avatar
danrs2k
focus st170 front disks and pads thats what i fitted to mine and they work a treat 300mm so they look big behind 17's
** if you decide to fit these you cannot fit any alloys back on unless they are 17's **
Old 16-07-2008 | 12:06 PM
Maki's Avatar
Maki
does mondeo setup bolt on or it needs spacers like on MK4?
Old 18-07-2008 | 05:01 PM
burnzy's Avatar
burnzy
burnzy
cheer's for the advice lad's sorry haven't replied earlier i'v been stuck in london working
but puttin 300mm rotors on the front would be a big bonus .. n from ridin my bikes i no how important good brakes can be lol, was just wonderin how hard was it too fit the st170 setup n did you have to get a braket make for the caliper or was it bolt on, n well havin to get 17" compo's to fit over them, i could think of worse thing's to spend my money on lol .. n i had a suspision that i might be pushin the master cylinder so would an rs2000 one cope with 300mm's on the front or would there be a better replacment..
for the help every one
Old 01-09-2008 | 12:22 PM
danrs2k's Avatar
danrs2k
St170 brake set up was a piece of piss mate have a look in my thread no extra brackets needed and master cylinder can cope no problem. I will be uprating my brake hoses tho to goodridge ones.
https://passionford.com/forum/restorations-rebuilds-and-projects/135734-my-escort-rs2k-2wd-small-updated-23-11-07-a.html hope this helps.
Vincereese
01-06-2023 09:14 AM
SmudgerByName
52
28-07-2016 06:14 PM
FlashRS
14-09-2015 12:36 PM
Vincereese
18-08-2015 03:57 PM
Vincereese
16-08-2015 06:38 PM
Quick Reply: escort mk5 best value brake upgrade
