odd noise fom zetec engine
Old Jul 9, 2008 | 09:37 AM
Dave SCP's Avatar
Dave SCP
Default odd noise fom zetec engine
Hi Guys ,
I've got a fiesta 1.25 zetec and on revving the engine at low revs , it struggles a bit and there's a sucking noise from by the front of the engine/manifold area
Any one got any ideas ?
Dave
Old Jul 9, 2008 | 09:41 AM
ZetecCF's Avatar
ZetecCF
air leak?
Old Jul 9, 2008 | 09:51 AM
Dave SCP's Avatar
Dave SCP
Originally Posted by ZetecCF
air leak?
Gasket or manifold ???????
is it common for the manifolds to crack ?? it looks from as far as i can see to be in quite good nick
Old Jul 9, 2008 | 09:53 AM
ZetecCF's Avatar
ZetecCF
would have thought it would be gasket...
how noisey is it?
are your revs high on idle... and is it coughing...
Old Jul 9, 2008 | 10:10 AM
Dave SCP's Avatar
Dave SCP
Revs seam ok on idle , its just when you pull away or blip the throttle you get the sucking noise and it splutters , as you go up the revs its fine , its just at the bottom end, the sucking noise is noticable with the bonnet down from outside the car
Old Jul 9, 2008 | 10:13 AM
ZetecCF's Avatar
ZetecCF
hmm... I'd get your head in there and have a good listern to see if you can ID where its coming from... would have though gasket manifold interface...
JoeyBoyden
Jan 4, 2024 02:36 PM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
Churtz
15
Aug 13, 2015 06:40 PM
track.focus'd
Aug 12, 2015 05:53 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
