Replacing Manifold Nuts
Old Jul 9, 2008 | 07:32 AM
spoilt_rs's Avatar
spoilt_rs
Default Replacing Manifold Nuts
I have recently removed the head of the saff to replace the head gasket.
I was aiming to replace the nuts when i refit the manifolds, as the ones i have taken off are worn and slightly rounded, and i dont want to have a problem removing them in the future.
My question is, is there a specific type of nut i should be using? the ones removed have some small slots in them. I can pick up some stainless steel or normal mild steel ones from work..
Cheers.
Old Jul 9, 2008 | 08:00 AM
Rabbit's Avatar
Rabbit
You should use the same type as the ones you removed, these are metal locknuts. Normal nuts will fall of due to vibration.
Old Jul 9, 2008 | 09:00 AM
spoilt_rs's Avatar
spoilt_rs
that makes sense, thanks for your reply.
Old Jul 10, 2008 | 05:20 AM
Std nylock nuts will be fine on the inlet side, but exhaust side needs either the correct ones or K nuts, another way is to use SS nuts but squash them slightly in a vice so they are ever so slightly out of shape, this will make them stay on.
Old Jul 10, 2008 | 07:19 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
I would have thought you'd be better off using the copper nuts.
Old Jul 11, 2008 | 06:11 AM
Copper would be best, but I've never had aproblem with SS smothered in coppaslip.
Old Jul 11, 2008 | 08:08 AM
spoilt_rs's Avatar
spoilt_rs
Cheers for the reply guys, have looked at the k nuts but they are very expensive! 75p each, maybe they are overkill?
I am going to a nut and bolt shop on way home from work today, are the copper nuts best? and are they just a standard m8 or so they have a locking feature?
Also, what is copperslip, have not come across that before...
Cheers.
Old Jul 11, 2008 | 10:13 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Get in touch with Matt Lewis on here. Does all the studs, washers and nuts for around £60 i think which is good
Old Jul 11, 2008 | 02:57 PM
Dangerous Malcolm..
You can get the copper nuts from GSF, the 8mm are 25p+vat and the 10mm are 40p+vat. The ends are slightly oval so won't vibrate off.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
NC53
Sep 13, 2015 03:05 PM
Si B
Sep 12, 2015 06:49 AM
