RST gearbox prob - no reverse
Old Jul 5, 2008 | 10:00 PM
7xrskb's Avatar
7xrskb
Default RST gearbox prob - no reverse
My mate has got a S2 RST gearbox in his XR2 track car and has been ok until now. The other day it just would not engage reverse for some reason. All other gears are fine and no tell tale whines or noises when on the move. The gear linkage is ok and set correctly, we even swopped that over to eliminate it as a possible cause. Oil level is ok too.
Has anyone got any idea as to why it woun't engage reverse ?
Any help appreciated.
Thanks.
Old Jul 6, 2008 | 02:39 AM
NEWTON's Avatar
NEWTON
Thanks.
hi kev you can adjust the reverse gear inside the box,i had a simlar problem as reverse kept on poping out of gear.....take the fifthed gear of and you can get to it,you need to losen the 13mm bolt off and turn a straight headed screw tight and lock the 13mm bolt back up...hope it makes sence to you
Old Jul 6, 2008 | 02:40 AM
NEWTON's Avatar
NEWTON
im rebuilding a box in a couple of days.....ill take some pics for you if you can wait mate
Old Jul 6, 2008 | 08:13 PM
7xrskb's Avatar
7xrskb
Hi Craig,
If you can take a few pics when you rebuild the box that will be a great help. Yeah I know which bit your on about and if i'm right this can be done without taking the box out.
How's your motor coming along ? still working on mine.
K.
mjonathan24
Oct 29, 2015 10:39 PM
A.t.p
Oct 23, 2015 07:54 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
