s1 prob :-)
Old Jul 4, 2008 | 06:16 PM
glenn s1 rst's Avatar
glenn s1 rst
new to ford scene
Default s1 prob :-)
had my series 1 tuned and rolling roaded today, the guy couldnt do it because it misses badly when warm? so far i have changed:
plugs
leads
dizzy
rotary arm
and ignition coil.
i still have the problem, and was just wondering if any1 else has had this prob before it costs an absolute fortune finding this fault when could be simple???? thanks
Old Jul 4, 2008 | 08:37 PM
gup's Avatar
gup
poss the green coil wires arking out on the intercooler mine started to do that was a right pain to find as it was only doing it every know and again
Old Jul 4, 2008 | 08:39 PM
Stu @ M Developments's Avatar
PassionFords Creator
If i was having a Ł1 bet, i would say.
"Unplug the amal valve mate, its shorting the ecu out."
Old Jul 4, 2008 | 08:47 PM
gup's Avatar
gup
ooops i think i read it wroung lol
Old Jul 4, 2008 | 08:48 PM
I dont mate, yours is a good suggestion. The green wire can inded cause a miss when it shorts to earth intermittently, although its normally more of a total cut dead.
Old Jul 4, 2008 | 08:51 PM
gup's Avatar
gup
true my one made all my gauges start flashing every now and again under a little right foot it would pop and hold back then some times it will be fine for a week or so
Old Jul 4, 2008 | 10:54 PM
doogie's Avatar
doogie
just a though mate, i had probs with mine when warm and it turned out it was over fueling like a mother f*cker.due to the coolant temp sensor..its wortha try,there not expensive and can cause nasty probs....you'v changed alll the usual suspects..give it a try...it under the inlet manifold
Old Jul 4, 2008 | 11:11 PM
Even the worst tuner would have checked for overfuellng,so cant be that.
Old Jul 4, 2008 | 11:22 PM
doogie's Avatar
doogie
true mate ,but its a two min check with a multi meter on the sensor, it caused me a bit of a headache, just a thought pal.hope you sort it
yorkie92
27
Sep 22, 2017 05:56 PM
gcfcos
59
Oct 6, 2015 05:04 PM
gcfcos
88
Sep 15, 2015 03:48 PM
ray barker
Aug 7, 2015 09:00 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
