boost gauge not reading correctly
Old Jul 1, 2008 | 07:55 PM
proboscus's Avatar
proboscus
Default boost gauge not reading correctly
i have just fitted a rs500 dash into my sapp it has the boost gauge in the rev counter.all the boost pipes have been changed since i ran it last.what is happening now is when the engine is off the gauge reads zero then when started and ticking over it reads -10 but when i rev the engine and go on the boost the gauge does not go over zero.i dont think i have but just in case could it be that the amal valve pipes have been reconnected in the wrong order and if so could anyone please tell me which outlet connects to where from left to right or any other suggestions please
Old Jul 1, 2008 | 08:28 PM
LHD220Turbo's Avatar
LHD220Turbo
it wont go above zero unless you are actually driving the car - at idle it creates vaccum hence why it reads below zero
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Russ Payne
Sep 25, 2015 08:29 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
