Fitting Air con to a sapphire, Help needed.
Old Jun 27, 2008 | 09:25 PM
CozzyKing's Avatar
CozzyKing
Default Fitting Air con to a sapphire, Help needed.
Hi there everyone, I am after some help in relation to fitting Air conditioning to my sapphire.
I want to fit a/c to my car but was wondering with it being a late 1991 sapphire as to whether the loom will already be there or will I need to add an extra auxiliary loom for the system to work?
If anyone has any thoughts on this can they get back to me please.
Old Jun 27, 2008 | 09:30 PM
louie1's Avatar
louie1
Talking air con
tbh i considered fitting air con and its so much hassle i didnt bother, just drive fast and open the windows not the same but close
Old Jun 27, 2008 | 10:02 PM
iansoutham's Avatar
iansoutham
OCD Victim
Bulkhead is different for a/c models (bulge to accomodate the extra pipework, etc)
Can be done, and has been, but is a lot of work
Old Jun 27, 2008 | 10:05 PM
trevCOSS's Avatar
trevCOSS
as above just open the window
Old Jun 27, 2008 | 10:50 PM
spoilt_rs's Avatar
spoilt_rs
I'm having a nightmare pulling mine out, let alone fitting one!
Old Jun 28, 2008 | 06:02 AM
When I did this to a mk1 sierra, I had to cut a big hole in the area at the back of the heater as well, as the new "fan box" went inside the car above the heater box, as said a lot of work, but worth it if you want it bad enough.
Old Jun 28, 2008 | 07:17 AM
My cossie had aircon but it didnt work. I just cut off the old aircon pipes and pulled all the wiring out. My cossie had an after market aircon system fitted to it and there is a hole in the bulk head where the old aircon motor used to sit.I would just leave it as it is and if you get hot just wind all the windows down.
Old Jun 28, 2008 | 07:22 AM
neil andeRSon's Avatar
neil andeRSon
i was strugling to get mine out aswell. turn's out i missed a bolt in the bulkhead and the pipe work an rad came out in one bit..
and the weight you loose is unreal.. the pump is a heavy mother of a thing!!
Old Jun 28, 2008 | 08:30 AM
CozzyKing's Avatar
CozzyKing
Thanks everyone, you made me feel so much better about my purchase now
Not to worry though as I am sure I can sell it on on ebay.
Old Jul 2, 2008 | 02:17 PM
CozzyKing's Avatar
CozzyKing
Have you still got any of the parts from yours at all as I have decided to put it in anyway and need the thin pipe that goes into tha ac air box on the bulkhead?
Old Jul 2, 2008 | 04:58 PM
neil andeRSon
yea m8 i do somewhere. how desperate are you as i won't be out at the car till next week sometime.
Old Jul 3, 2008 | 10:24 PM
CozzyKing's Avatar
CozzyKing
I'm not desperate desperate m8 but could do with finding a replacement as sierrashack on ebay aren't gona replace it by the looks of it.
matman
Sep 9, 2015 05:45 PM
markk
18
Aug 17, 2015 05:19 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Aug 9, 2015 07:03 PM
Old ford
Jul 31, 2015 06:50 AM
