Plumming up S.P.A gauges
Old Jun 22, 2008 | 08:57 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
Default Plumming up S.P.A gauges
Now that i have my engine stripped and sorted out, its time for the rebuild. in doing so i have decided to plum in the 'S.P.A Design' gauges i have. The gauge was mounted in the car when i bought it but never plummed in. The gauge is for oil temp and oil pressure. were and what do i 'tap' into to connect these???
i 'think' one is by the oil filter, and the lad i bought the car off said he had to buy a smaller adapter which i have, to clear the filter.
anyone???? lol
Old Jun 22, 2008 | 09:02 PM
rapidcossie's Avatar
rapidcossie
I have my oil pressure/temp tapped into the block for my low oil press switch that screws into the side of the engine block.
Old Jul 7, 2008 | 08:59 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
so have you tapp'd into the switch behind the oil filter?
Old Jul 7, 2008 | 09:08 PM
rapidcossie
yeah for oil press and temp
Old Jul 8, 2008 | 05:37 AM
You could do that or take the temp reading from the sump, by making a fitting on the sump whilst engine out.
Old Jul 8, 2008 | 09:28 PM
Mike1's Avatar
Mike1
My oil pressure switch is tapped into there as well.
The oil temp sender is plumbed into a special fitting on the sump....prevously it fitted into a specially modified sump plug that Mike Rainbird was able to get made up at an engineering place local to him. That did the job just as well to be honest and was easy to fit at the time of the next oil change
Old Jul 14, 2008 | 06:45 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
maybe these can help shed light on the problems..... these are the fittings and sensors which came with the kit. do they look like everyone elses????
oil temp sensor
pressure sensor
pipe work
adapter
instructions (easy to follow - if i knew were to go from first lol)
Basically how would you lot go about plumming these in if you had to do it with these type of sensors.
regards, Riggie.
Old Jul 14, 2008 | 06:48 PM
rapidcossie
you have a 4x4 engine then as you dont have the oil feed to the turbo coming from where the standard low oil press switch is.
To fit the gauge you need to remove the standard oil press switch and screw the copper coloured fitting in to the block and then attach all the senosrs to the block.
rapidcossie
that small copper fitting is a drilled out sump plug.
you could put the oil temp in there.
Old Jul 14, 2008 | 06:59 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
If thats a sump plug fitting!!!!! i bloody hope so, that would make it all easier. it i fit the temp in the adapter in the sump, then plum the pressure switch into the sensor behind the filter using the double adaptor. that way i will have the SPA gauge and could still plum the original oil pressure switch in too.
Old Jul 14, 2008 | 07:11 PM
rapidcossie
yeah you should plum orginal switch in too mate.
Old Jul 14, 2008 | 07:12 PM
Riggie's Avatar
Riggie
Series 1 RS Turbo
that all makes sense now. sorted. proper chuffed now lol. thanks. Riggie
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
