engine management reset?
Old Jun 21, 2008 | 11:28 AM
Cossy Mike's Avatar
Cossy Mike
Unhappy engine management reset?
Does anyone know how to reset the engine management light on my 2001 Mondeo Mk3?
The petrol cap was loose and I have been told this might have been the cause for it to come on. I have tried disconnecting the battery and its still on.
The dash code says it has no fault. It says dtc-none. another code is on the digital dash dt684E.
Anyone any ideas? it drives ok
Thanks!!!!
Old Jun 21, 2008 | 12:57 PM
Cossy Mike's Avatar
Cossy Mike
anyone?
It's due an MOT next week will this affect it?
Old Jun 21, 2008 | 07:52 PM
You only need to pull the VILOET 3 amp fuse marked KAM, for a minute or two to reset ecu.
If the power disconnection has not worked, then it needs clearing and resetting at dealers.
Old Jun 22, 2008 | 06:46 AM
Cossy Mike's Avatar
Cossy Mike
Thanks, the battery disconnection worked. Where would I locate the KAM fuse for future reference?
Old Jun 22, 2008 | 09:02 AM
dave green's Avatar
dave green
And it will not effect the mot
Dave
Old Jun 22, 2008 | 09:27 AM
COLEYST200's Avatar
COLEYST200
You would be best of on a mondeo site lick the one im a member of there a good bunch of lads and one of them will no wot to do to sort it out for you
http://www.fordmondeo.org/
Old Jun 22, 2008 | 04:24 PM
fonfe's Avatar
fonfe
id try a hard reset if still no joy as it work on range rovers and most newish fords to clear fault codes if they are not present faults.
disconnect both the negative and positive leads to battery, leave for 1min then place a bar of metal in between them (the leads NOT the battery) easiest thing to use is a long 3/8th extension bar and leave for 2 mins. do this when ever i manage to beach a range on a ramp at work and someone else is using the diag computers on another car, not saying it will 100% work but it may as it clears everything off our cars and the software is fords IDS so it could work, certainly wont do any harm to try it?
Old Aug 13, 2010 | 06:12 PM
ian burt's Avatar
ian burt
Wink ian
thanks. done wot u sed it worked 1st time cheers
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
liam-rst
Aug 10, 2015 08:46 AM
Old ford
Jul 31, 2015 06:50 AM
