XR2 K&N and webber carb fitting problem!!!!!!!!!!!!!!!!!
Old Jun 20, 2008 | 11:12 PM
robotrhys's Avatar
robotrhys
Default XR2 K&N and webber carb fitting problem!!!!!!!!!!!!!!!!!
Unfortunately the K&N air filter i have bought off a friend for my xr2 will not fit my carb. The mounting plate is square with four screw holes and my carb has three screw holes within a circular surrounding lip.
Please see the following links for pictures of the currently installed airbox and the K&N mounting plate supplied.
If there is anybody who has any idea what i could do to get the K&N to fit or the reason why it doesn't fit my carb please reply to this topic!
I am aware that there were two webber carbs made for the xr2, is this the K&N for the earlier carb?
http://www.facebook.com/album.php?aid=23809&id=504463359
__
http://www.facebook.com/photo.php?pid=547197&id=504463359
http://www.facebook.com/photo.php?pid=547197&id=504463359#pid=547198
http://www.facebook.com/photo.php?pid=547197&id=504463359#pid=547199
http://www.facebook.com/photo.php?pid=547197&id=504463359#pid=547200
Old Jun 21, 2008 | 08:49 AM
turbozvh's Avatar
turbozvh
you have the tld carb which is the right one for an xr2 and i think the square top one is of a xr3 you could get a xr3 carb or just sell the air filter you have and get one that fits on the tld carb i have a push on weber filter looks the same as the xr2 one pm if interested have you got the bigger jet that comes with the filter?
Old Jun 22, 2008 | 04:28 PM
fonfe's Avatar
fonfe
make up a adapter plate, thats all i did, get some sheet metal, cut it to size to fit on your carb with the bolt holes in the right place then adapt that to fit onto the k&n.
thats all i did putting square top carb filter onto a round a round top one then did it again to swap back again. if you have the auto choke id ditch it though as they are crap and make up a manual choke conversion for it.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Dr. Ickxs
Aug 15, 2015 11:34 AM
druidgetafix
Aug 15, 2015 10:22 AM
mick pearson
Aug 9, 2015 09:19 AM
baz
12
Aug 4, 2015 10:01 PM
