L8 vs P8 ECU
Old Jun 20, 2008 | 02:34 PM
Spotmatic's Avatar
Spotmatic
Default L8 vs P8 ECU
Hello all,
I've got a problem with my (stage 1) Escort Cosworth (P8 ECU). My Escos doesn't pass the Dutch MOT (APK) because the CO level is to high (3000 rpm 0.97 wich should be 0.39). I run a turbo back Magnex in wich i've welded a 3" racekat.
As the P8 ECU doesn't have a mixture ajustment screw i thought of fitting a L8 ECU (only for the test). I've been told the L8 ECU does have a mixture ajustment screw, swaps straight on with the P8 ECU and can run the "P8 Escos".
Do you know if this is correct? I could also try to find a standard chip but i don't know any (i'm in The Netherlands) and i do know a standard L8 ECU.
Regards,
Mark
Old Jun 20, 2008 | 02:43 PM
white4x4cos's Avatar
white4x4cos
The ecu's can be swapped straight on.
Only the P8 uses a 2.5B map sensor and a L8 2.0B map sensor.
Old Jun 20, 2008 | 02:48 PM
Spotmatic's Avatar
Spotmatic
Thanks for the quick reply! Would the MAP sensor cause a problem?
Old Jun 20, 2008 | 02:51 PM
white4x4cos
Yes would be best to swap the map sensor aswell.
Old Jun 20, 2008 | 02:57 PM
Spotmatic's Avatar
Spotmatic
Ok, thanx. Could i also fit the ajustable Sierra fuelpressure regulator to reduce the CO level? Instead of changing the ECU and MAP sensor?
Old Jun 20, 2008 | 03:21 PM
white4x4cos
You might even try a fuel regulator from a rs 2000 that's a straight swap to a escos fuel rail I believe it's 2.7 bar FPR.
It could help for MOT but don't drive it hard with it.
Old Jun 21, 2008 | 09:59 AM
Spotmatic's Avatar
Spotmatic
Smile
Thanks mate, yesterdayevening i've picked up a L8 ECU and a 2bar mapsensor.
Old Jun 23, 2008 | 03:14 PM
Spotmatic's Avatar
Spotmatic
And today my Escos passed the Dutch MOT; CO 0.08 and Lambda 1.06 .Thank you again!
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
